Charging System Not working - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2005, 01:55 PM
rbfpezcore's Avatar
Not fast, but loud as hell
I have a 62 cadillac and the charging system is not working. At the battery I have 12.7v. When i turn the car on, I still have 12.7 volts. At the generator I have 14v and further down the circuit at the fuseable link, I still have 14v. The wiring diagram shows the circuit leading to the generator tell tale light, which is still operational, then onto the thermo gauge where it gets its ground. As far as I can tell it is still grounded since the generator tell tale light is still working. Any ideas?
Old 06-13-2005, 06:02 PM
docvette's Avatar
Wiki Edits: 12
Generator
Doc here,
The oldest Diagram I have on this hard drive is 63-65 GM charging system..And since it's a cut off date (62/63) May not apply to your car...Mine does not show the Charge light, or This Thermo?? Switch you speak of...
However, I can give you SOME advise..
First if you have 14.4 Volts at the generator..and all the way to the fusible link, Your Generator is operational..Check the Power back to the Battery (and cable terminals ) For loose or corroded connections..
Make SURE you have a proper Ground From your generator to the Engine block AND Battery...If you have to add a 10 Gauge wire from the generator Body to your main grounding are (which, If done properly, should be located at or very near the starter, on the block)
After you Check or repair those..If your still low back to the battery, check and adjust the Regulator (or just replace it) Both the Air Gap and field contacts...0005 and 0064 thousands or there abouts..Make sure the point rocker is actually closing and that the regulator functions..
You may also have a second Fuse link at the Horn Relay, Look for that, as this is what provides direct power to the generator..
Also .. Unlike Altenators...Generators ARE RPM dependent..be sure you have enough RPM when you take your readings...If necessary..turn up the Idle screw around 1200 rpms...
Hope that gives you a start point..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-13-2005, 06:06 PM
poncho62's Avatar
Wiki Edits: 5
Enlighten me Doc, but did they have fusable links in 62?
I am pretty sure that I never have seen one on my 62 Pontiac.
Old 06-13-2005, 06:21 PM
docvette's Avatar
Wiki Edits: 12
Fuse link..
Doc here,
You may well be quite Correct..My diagrams Don't show a fuse link in the Charging circuit until after 65...So It is quite possible..
However HE SAID he has a fuse link, so I assume they did...OR somebody (and rightly so..) Installed the protection at some later date...Which now makes it part of the mix...
If your Running without one, you might want to consider the upgrade just for the extra protection..Cuz accidents do happen...better a link than a harness or your whole rod...
Doc
Innovations
Old 06-13-2005, 06:22 PM
rbfpezcore's Avatar
Sorry, my use of fuseable link is a little loose and i probably shouldnt have used that. What i mean is there is a fuse in series with the circuit. Sorry.
But first thing tomorrow I will check the ground to for the generator which is what I probably should have done before coming on and asking questions. Thanks
Old 06-16-2005, 02:38 PM
rbfpezcore's Avatar
Correct me if I am wrong(and i usually am), but the generator casing should be grounded? So two bolts would most likely be the grounding point? I cannot find a strap for the generator like the one I have on my starter. Is this how it should work? Thanks
Old 06-16-2005, 05:10 PM
docvette's Avatar
Wiki Edits: 12
Case Ground
Doc here,
Yes The Alternator MUST be case grounded...Do not relay on the mount bolt to the mount to do that job for you...
Isolate where your grounds come together, should be at or very near the starter on the block...
Run a 10 gauge wire from the main grounds at the block to the Alternator Ground lug..Should be a single nut on the back..attach your ground there..If you Don't have one...then to a mount Bolt ON the alternator itself.
Use star washers and burnish off all grease, paint and corrosion.
If you have an aluminum mount bracket (the big one on the block) and it is powered white..along with the alternator case..you have electrolysis...and probably no ground..
Remove the mount and the hardware, water blast or sandblast the mount and hardware, and reassemble, using Aluminum wire bonding paste on the hardware.
You want to clear this up, because the electrolysis will eat the water pump Vanes up until their non~Exsistant...over time...
Your grounding system must be arranged in this fashion in order to be effective...
Main battery Cable from battery to a bolt on the block at or near the starter..from that bolt run a battery cable with 2 ring terminal ends on it (6 bucks at the auto parts store) to the frame and ground it...
From the same block bolt run two 10 gauge wires, one to attach at the firewall, and the other to attach at the Alternator case.
Burnish paint and grease at each ground point and use a star washer at each, be sure all are tight.
From your very first post you said you have 12. 5 volts on the battery side of the fuse and 14.4 on the Alternator side of the fuse?...correct? If that is so...therein lays your problem...that fuse is blown or not making contact...Don't relay on visual, use a test meter or lamp to check the fuse..
what you may have is 12.5 volts from the battery, and 14.4 volts from the charging system stopped at both sides because the fuse is open...
Doc
Innovations
Old 06-21-2005, 11:28 AM
rbfpezcore's Avatar
Again, you were right. The grounding for the case was no working so well. The grounding lug was a bit rusty and grimey. I found a new one and bolted it on, after starting up the car the charging system kicked in fine. Thanks a lot Doc!
Old 06-21-2005, 06:52 PM
docvette's Avatar
Wiki Edits: 12
The Fix
Doc here,
Thanks for posting back with the fix! It might help the next guy...
Glad to help...
And Happy Rodding!
Doc
Innovations
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
Designing the fuel system 66Caprice Engine 9 05-12-2005 02:57 PM
AWD system... muscarmad Transmission - Rearend 6 03-28-2005 11:52 AM
Vintage auto alarm system????? 421Bonneville Electrical 2 09-17-2004 05:53 PM
Airlines Kevin45 Garage - Tools 22 03-04-2004 04:35 AM
