charging system trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2009, 03:11 PM
i have a 1979 caprice with a good (tested) battery and brand new (now tested) alternator. the other day i gave my buddy a jump and he hooked up the cables backwards for about 1 second before i smacked him upside the head for it. that night my lights went very dim so im wondering whats burned up. what should i check? car runs and drives but only makes 12.2 volts even when running. alternator is new and tested as well as battery. are there any fuses that would stop my alternator from charging the battery? alternator light stays on now.
Old 02-12-2009, 05:32 PM
jump a wire from hot terminal on alternator and to hot side of battery .
it should start to make the charging wine at the alternator .
fuse able link may have saved you .
Old 02-12-2009, 05:48 PM
T-bucket23's Avatar
Wiki Edits: 26
Most likely you burnt a wire or a fusable link. Check everything. The above post has some good advice in it also.
Chet
Old 02-12-2009, 07:27 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If it is wired like my 79 pick-up
There are 2 fusible links down by the starter.
My volt meter did different things when one or the other went out
????does the radio come on?????-----this would be one link (ACCY)
????does the cigarette lighter work???---this would be the other link (BATT)
Old 02-12-2009, 08:08 PM
thanks guys i will check everything and get back to you tomorrow morning
Old 02-13-2009, 06:04 PM
it was the wire conn. in the back of the alternator. i put in the 3 dollar one wire conversion pigtail and solved the problem. woohoo thanks guys
1970chevy c10 charging system probs RossB_1970C10 Electrical 2 01-24-2009 10:41 PM
theft system trouble car maynot restart koop Electrical 1 10-30-2007 08:32 PM
Charging System Not working rbfpezcore Electrical 8 06-21-2005 06:52 PM
charging system problems mmartin1872 Electrical 3 11-07-2004 12:51 AM
