Charging woes!
Hey All.
Got my Gremlin back last nite and although it runs pretty good, It wouldnt start last nite. I got a jump and it fired right up, but when I took off the positive cable, it died. I figured the alternator, but had it checked and it checked good. I bought another anyway, but its doing the same thing! I still have the box(cant remember) mounted on the iner fender that the cables run thru. Could that be bad? I cant figure this one out? Help. HG
Would that cause it to die when I take the cable off while its running? I was told it would mean a bad alternator, but it tested fine. HG
Does your gremlin have the external voltage regulator? My 69 Rambler wasn't charging and would die when the positive battery cable is removed. I replaced the regulator and the problem was taken care of. You can replace the alternater/external voltage regulator with a GM one wire, you just have to make a special mounting bracket. Or if you want to retain a stock look, Kennedy American in West Jefferson, OH has the voltage regulator. PM me for more info.
The voltage regulator should be a black or grey box with 4 or 6 wires coming out of it mounted on your driver's side inner fender. |
