Sounds just like the gremlin that I had last year. I thought it was ignition related and I upgraded everything with no luck. I would think at times it was fixed but then it would prove me wrong. I switched to an electric fuel pump and the problem was gone for good.
BTW, good job on the carb tuning as well as the timing. A LOT of guys stumble (npi) on this.
Chasing a ghost in a 350 SBC.
I read in one of your post about the trash you found in the 4150 carb. What type fuel filters are you using? Most manufacturers recommend a 100 micron filter at the tank. Also a 40 micron filter in the line up front. Another interesting thing I read the other day is not to use teflon tape on any gas or oil fittings. It said to use a paste type sealer with teflon in it. I used Permatex 59235 when rebuilding my engine last year. You have replaced everything in the ignition system and it hasn't fixed the problem yet. How about your fuel. Gas with 10% ethanol has a shelf life of about 3 months. The ethanol absorbs water from the atmosphere. I have heard of using a timing light to watch the gas as the carb squirts the gas. IDK but it is said you can see water in the gas. Here is the article (advertisement) i was reading. USA Fuel
I was using a summit racing summit racing 110 gph mechanical pump. I had installed it over the winter along with some other changes is why it took me so long to figure it out. I would swear that our description sounds just like my nightmare. It cost me a small fortune to figure it out.
Yeah, I think that pump might be suspect too. Probably losing volume as rpms increase. Try your electric pump maybe it will be the fix. Hope it works for you.
Drove the car again today to work. 32 degrees this morning. Ran decent but the slight hesitation was back at part throttle. Now it's 60 degrees and the car is running awesome. Seriously thinking the RPM Air Gap isn't for cold weather! I hate to buy a RPM Vortec intake just to try. But I don't know of any to borrow. My heads are the Edelbrock E-Tech 170 so...
When it's cold, it runs between 170-180 degrees. When it's warmer it's running around 190. There is a 180 thermo installed. It does seem like it runs much better around the 190 range
I don't know if it mattered or not, but it is a late model roller Vortec block with one piece pan and rear main. Those engines use a 195 degree thermo I believe. But due to the carb intake I figured thermostat shouldn't matter? Would the combo of thermostat and spark plug heat have any affect?
| GoPro video, Bucket-T chasing down a motorcycle | deckofficer | Hotrodders' Lounge | 48 | 05-14-2011 08:39 AM |
| chasing pinholes. it worked...and didnt | glhx | Body - Exterior | 10 | 10-28-2010 05:34 AM |
| Chasing down a really annoying squealing belt! | killerformula | General Rodding Tech | 8 | 02-23-2010 11:31 PM |
| Chasing TPI Gremlins | trees | Engine | 3 | 10-17-2005 11:05 AM |
| Cruising or chasing sales? | tm454 | Hotrodders' Lounge | 3 | 08-30-2003 07:30 PM |
