Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chasing pinholes. it worked...and didnt
Old 10-27-2010, 01:33 PM
glhx glhx is offline
here is the inside where all the welding was done. most of the pin holes are filled. When ground down they mushroom and flatten the welded metal. i dont trust this to not re-rust. it seems porous and imperfect. if i put any chemical in there it will be hard to get it out. I dont have a sand blaster. It looks to me to be strong and feels strong.I used setting c on the welder with wire speed 3.
It took some time to figure out how to weld this thin metal. i started with low heat but it didnt work. The other roof rail if fill welded wont be this messy and doesnt have as many holes. i created and had to fill more holes due to not knowing what i was doing. Once i figured it out they started to fill and not creat new holes. must have 10 hours in fill welding.
how can i make sure this doesnt re-rust
ID:	49278   Click image for larger version
ID:	49279   Click image for larger version
