Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chasing pinholes. it worked...and didnt
Old 10-27-2010, 03:03 PM
glhx glhx is offline
I also wish i could figure out a way to keep this roof from re rusting surface rust. as you can see in the pictures it already has.Ive heard of picklex 20 and all the other acid based rust removers working well............but ive heard people dont like to use them, because they make epoxy primer not stick. Is there any way to use picklex 20 for now and then remove it when im ready to primer. any ideas. I used naval jelly and it removed all the rust. 2 days it was back and ill have to apply it over again. i used thinner to remove it. i know epoxy primer doesnt like thinner coated metal. so u hit it with 80 grit in the past and it stuck just fine. can i do this with picklex 20
