Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chassi engineering bolt on independant front suspension on 41 chevy??
Old 05-07-2011, 10:54 PM
cpg2 cpg2 is offline
I put a bolt in CE front in a 39 Chevy. It fit really well and was easy to do. Way better than using a clip. Used stock MII spindles and it is low. Bought 4 cyl MII springs at parts house and had to cut about two coils off. I also used the CE trans crossmember and braces as well as the radiator support that allows you to put a sway bar on. It all fit perfect and does not look bad at all like I thought bolt on stuff would.
