Chassis - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2007, 09:28 AM
Chassis
Hi. . Just Would Like To Know If U Can Use A T Bucket Body On A Chev. S Ten Chassis ???? If So What Changes Do I Have To Make. Body Mont's So On ??????? Thanks In Advance. :d THANK FOR SOME OF THE INFO I READ THAT MEANS NO TO S TEN
Old 10-23-2007, 10:58 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
A s-10 chassis is way too wide for a T-bucket. Use the search function on this site to find T-bucket chassis info. Building a T-bucket frame out of rectangular tubing is fairly easy. You can also buy frames for T-buckets...check out Speedway. www.speedwaymotors.com
Old 10-23-2007, 01:25 PM
Irelands child's Avatar
Dang - an S-10 chassis might be the best thing since granny's apple pie - for an S10 pickup truck. It is not the correct frame for most street rods, regardless of what the ratters say. It's too long, too wide, too deep, too many brackets that have to be removed and so on, and on, and on, and on . There are too many good to great after market frames to choose from and cars like Model A's, T-Buckets, early Chebbies and even '32's with ASC rails or some other supplier. A T bucket or an A can be fabbed in a long weekend with plate stock and some rectangular .125 tubing for about 100 - 150 dollars and a MIG welder.
Dave
Irelands child
Old 10-23-2007, 03:33 PM
cyclone-rods's Avatar
Bodies, Frames & Radiators
Easy & cheap T-Frame:
http://www.tperformance.com/street_r...-it_frame_kit/
Which Chassis finish would you choose from these 2 options? uglyjeep Body - Exterior 11 10-10-2008 11:17 PM
34 Ford - Title stay with chassis or body? heyjude076 General Rodding Tech 3 05-28-2007 06:27 PM
s10 chassis vs. tube chassis penguinoitaliano Suspension - Brakes - Steering 2 12-28-2006 08:40 AM
First stage of rebuild, chassis first? Oz GMHR General Rodding Tech 6 06-26-2005 11:36 AM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 06:50 PM
