Chassis building for my '35 Pluymouth coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2005, 07:21 PM
Hey guys!
I'm new here, so I apologize up front for violating any rules or customs I don't know about.
I am thinking through building a frame for a '35 Plymouth coupe I picked up a few weeks ago. It will be a budget deal, like all my car and truck projects.
I built a frame back in '99 for a t bucket. It came out real well, the car works great, and has been on the road 4 seasons now. The frame is pretty much 2X3X3/16 steel, with rifle barrel quality 7/8 tubing for the radius rods, drag link, tie rod and such. I made all that stuff too, reversed a Corvair steering box for it, made all the engine/tranny mounts, etc.
I had one guy tell me such a frame set-up would not work under a coupe, but I don't see why not. On the other hand I've had a number of rodders say "Why not?"
So anyway, this is the way I'm leaning. Dropped front axle, transverse spring behind, Corvair steering, radius rods, z'ed frame, pretty much like my bucket. The coupe I got is just the body, cowl back, no fenders, and that's the way I intend to keep it. Easy to channel! I'm looking right now for a donor Mopar vehicle to cough up at least an engine and tranny, and maybe a rear end too. (AC would be okay too.) I would plan on making all the associated brackets.
Any ideas, hints, tips, suggestions greatly appreciated!
Frank
Old 07-12-2005, 10:38 PM
Why not?
The frame might not be exactily like a T bucket,but you certainly can fab your own. Look at a similar cars frame and take some ques from it. Lots of info on this site and rod mags as well. Makes you feel good to build one from the ground up,so to speak. Especially when thing work correctly. good luck, Jerry
Old 07-13-2005, 12:42 AM
dinger's Avatar
I'm with the "why not" guys. I would think that building the frame, "Z"ing, with the channeling, you could make a badarse stance to the car. With some crossmembers, I'd also think it would be stronger than stock. The mid 30's to early 40's are my favorite cars. I'm building a 36 Ford 5w coupe, the Dodge and Plymouth coupes are cool. The 35 and 36 are 2 of my favorites of that era for Chrysler. Good luck and keep us posted. Dan
Old 07-13-2005, 02:31 AM
Crazy Mopar Guy's Avatar
My frame is 2X3 square tubing. I use a clipped front and a cage, but it's not much different than what you plan....?
Old 07-15-2005, 01:33 PM
Thanks guys!
Frame won't be the same as the bucket, but not much different. It's a matter of a level frame and diagonals matching. It's being real careful not to warp the rear axle when welding brackets on. It's gonna be different, but not much. Did I already say that? I been chainsawing in very hot weather here near Albany NY today. Trying to get some of my land cleared off, took down 52 trees, now cleaning up. For this kind of power, can you say STIHL?
Anyways, my bucket came out good, fast, and straight down the highway. I love it. Matter of fact, won't be long I'll be in the shower, then hop in the bucket for a little rest and relaxation!
Frank
Old 07-15-2005, 02:27 PM
As one of the Moderators here........Let me WELCOME YOU.. here..
The only thing I see is the Corvair box........The coupe will weigh more than the T-Bucket and IMHO needs a stronger steering box.
I am usually against encouraging frame swaps, but you seem you be capable so.......I might consider a complete frame or adding a clip to what is under the coupe now. Mopar frames were very good and strong from that era...
Whatever you do.......have FUN and be safe......
Old 07-15-2005, 05:11 PM
Frank
Well come and pick me up for a spin!!!!!!
Drop Ron off at my house (he can work on my cars while we go out) and we'll rip up the town!
Old 07-21-2005, 11:13 PM
Last journal entry: Robs34 - Done my dash
Do it man !!
The guys who say you cant do things are usually the ones who couldn't do it themselves as it would be too hard !
Go ahead and make your own chassis I would suggest 3 or 4 X 2 tubing with 1/8 wall thickness, if you like have a look at my project, its a 34 ford with a tube chassis and a home made body. The chassis is close to your needs altho you are using four bars the X members are similar to your needs. I have added an unscaled drawing there as well so you can see how I strengthened the frame where it is cut and joined this made it very torsionally strong so the body does not flex at all.
BTW welcome!!
Rob
Old 07-23-2005, 12:51 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Found a couple of sites that might be helpful to you:
http://www.ply33.com/Models/PJ/
http://www.1935plymouth.com/
That last one is *stuffed* with info!
Old 08-15-2005, 08:34 AM
Thanks for all the support guys!
I haven't had much chance to work on the coupe lately. Been busy rebuilding an old vette engine I picked up, dealing with home improvement stuff, and suffering through one of the hottest summers on record.
Couple things. I figure being fenderless I'll be under 1,000 #s up front, which should be okay for a corvair steering gear. If it doesn't work, I'll switch it out, but I think it will.
I ran into a fenderless '32 Ford coupe at a cruise-in last month on a t-bucket frame just like what I plan on doing, with a reversed corvair gear. I didn't get to talk to the guy, as he was never around, then we had to leave a bit early. That cruise-in is this Wednesday. If it's decent weather, I'll drive the bucket over and see if I can find that guy.
Also, after much research and looking at a bunch of rods with 4 bar set-ups, I think I'll stay with radius rods. I know how to build them and feel more comfortable going that way. Also, I'm planning on air bags for my "springs" with shocks at each corner. Gonna start making those brackets soon and scrounge some parts for it.
"Crazy Mopar Guy" - where in Canada are you? I was born and raised and spent many years in Massena, NY, just opposite Cornwall ON.
Back to work,
Frank
Chassis building americanLT1 Suspension - Brakes - Steering 14 07-26-2004 07:14 AM
35 Chevy 3 Window Coupe paulm Body - Exterior 14 05-08-2003 12:37 PM
building a 1950 plym. bus. coupe. bdv Hotrodders' Lounge 5 01-25-2003 02:54 PM
