chassis Engineering MII suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2007, 07:05 PM
Its to time put front suspension under my 1949 f100. I am leaning toward the bolt on type from Chassis Engineering. Is there any opinions about going this way
bcovey
Old 11-17-2007, 07:48 PM
AntnyL's Avatar
Originally Posted by bcovey
Its time put front suspension under my 1949 f100. I am leaning toward the bolt on type from Chassis Engineering. Is there any opinions about going this way
bcovey
If you go that route, make sure to check the torque on all the bolts at regular intervals. The kit looks quite beefy, and I like the lower control arm/strut rod design. It looks like a solid kit.
Antny
Antny
Old 11-17-2007, 08:00 PM
302 Z28's Avatar
Not all Mustang II kits are the same. Check to make sure they follow the Mustang II geometry to the letter. Look for tie rod ends that pivot on the exact same plane as the lower control arm, this helps eliminate bump steer. Also look at the upper control arms to see if the front attachment point is higher than the rear, this is an anti dive feature.
Vince
Old 11-18-2007, 07:01 AM
I've had a CE bolt-in front end on my '38 Chevy coupe for several years with no problems at all.
Old 11-18-2007, 07:22 AM
poncho62's Avatar
Wiki Edits: 5
This other thread is suggested reading....lots of good info on these units.
IFS failure = tragic results
Old 11-18-2007, 11:21 AM
Ce Mii
I put a Chassis Engineering (CE) Mustang (M) II under my 39 Chevy about a year ago and have been very pleased with the ease in which it went in, how it sits and how well the car rides. I was also very pleased with the assistance and response from the folks at CE. Before I bought a MII I talked with alot of folks and alot of companies before I made up my mind. I went to alot of shows, listened to the questions asked and the responses the vendors gave to those questions. I was especially impressed with how the CE folks spoke and treated people and the information given to questions. I would even talk with people after they left the vendors to get their opinons and of the vendors and the experience they had with a MII. Of course I also asked owners who had MII's in their cars what they thought. In every case people were very pleased with the CEMII set up.the lots. So when I made the decision to buy the MII I was fairly confident I could get it done. However, what they didn't fully explain was that it is truly easy to install. Read the instructions several times before starting, measure everything several times, write the measurements down and take your time. The CE people are very helpful and responsive and if they make a kit for your truck, buy it.
Which Chassis finish would you choose from these 2 options? uglyjeep Body - Exterior 11 10-10-2008 11:17 PM
Chassis Engineering Dropped Axle Dugg Suspension - Brakes - Steering 4 09-28-2007 08:12 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
strut suspension for tube chassis Kenwalk Suspension - Brakes - Steering 1 05-15-2003 07:59 AM
Chassis Engineering front 4 bar suspension 1940 ford hvyh20 Suspension - Brakes - Steering 1 10-17-2002 03:19 AM
