Which Chassis finish would you choose from these 2 options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2007, 08:57 PM
Hi, I am new to the forum and have been reading some past tech replies on the subject of chassis painting. While i do not have a hot rod, I do have an '46 Willys Jeep that I am doing a resto-mod on. I have a little dilemma that I'd love to see if you can help me through.
Here's the story...I had the Willys frame sandblasted and I used a single stage primer and Martin Senour chassis black to paint it with. While I love the look and finish of the semi gloss Martin Senour chassis paint, the finish is chipping off with even mild taps of a wrench. The primer looks to be holding fine but a good bond between the primer and chassis black did not occur. I use the jeep on gravel roads regularly, so this finish is not going to work for me.
I have decided to have the frame sandblasted over again, and I am considering two options for painting it with. I am either going to use the Eastwoods extreme chassis black and do it at home, or the blasting shop offers a chassis painting service that uses a two part epoxy primer with a urethane semi-gloss chassis black top coat. Both are comparable in price, and both claim to be extremely chip resistant, and both will get me the color and sheen I am after.
The jeep is not a show car, so I am mainly looking for a finish that repels chips and scratches. I am staying away from powder coating because I need to have a finish I can make touch ups on if the jeep is modified in the future. So which would you choose, the Eastwood product or the two part primer with urethane chassis paint?
Sorry for the long-windedness, I look forward to your opinions,
Thanks,
Daniel
Old 06-19-2007, 05:50 AM
2-3 coats of epoxy over clean blasted steel then topcoated with 3 coats of a quality urethane singlestage=hard to beat the durability offered with this combination.
Old 06-19-2007, 05:56 AM
302 Z28's Avatar
That depends on which brand of epoxy is used. If it is PPG DPLF I would vehemently disagree. SPI would be a good base for a qualty urethane though.
Vince
Old 06-19-2007, 01:15 PM
Last journal entry: Body work
Did you check into powder coating? I would think the cost would be comparable if you can have it done locally and It's very durable.
Old 06-19-2007, 01:27 PM
I considered powder coat, but I need a finish I can redo regularly as we modify the jeep, or if the finish gets damaged during use on the trails. I basically have my decision narrowed between the epoxy/urethane and the eastwood stuff, not sure which would be best?...
Daniel
Old 06-19-2007, 03:06 PM
Last journal entry: Latest picture
Epoxy and urethane!! Anything with a catalist will out perform one part systems
Old 06-20-2007, 12:18 AM
Heres ppg dplf, if you scratch it, you can touch it up with a cheap air brush, shouldn't even have to mask it.
http://www.1969supersport.com/047.html
Rob
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
Old 06-20-2007, 12:27 AM
Undercoat
Thanks,
Daniel
Hello Everyone, I'am New here Too. Can I Suggest a product called " ProForm" Paintable Rubberized Undercoat. One I have used is Black, and you spray it on with a "Simple Sprayer that you just stick in a quart can. I think it costs about $15 This Stuff is Great !!! Sticks like Mad, Paintable if you like. Covers minor blemishes, easy touch up. They also have a product called " Rock Guard " Put on some Old Clothes !!! You will have to throw them in the Garbage when your done. It's a Messy Job !!!
Old 06-20-2007, 05:46 AM
302 Z28's Avatar
Originally Posted by robs ss
Heres ppg dplf, if you scratch it, you can touch it up with a cheap air brush, shouldn't even have to mask it. Rob
That is because it is a very low grade epoxy. .
Vince
Old 06-20-2007, 06:14 PM
I have been VERY impressed with the Eastwood Chassis Black after using it for the past 10+ years on various projects, including my own. For a single stage it is very durable, extremely easy to touch up if needed and low cost. The Chassis Black will cover in one coat, so you are not going to go through a whole lot of mixed paint. I have used it over Etch and Epoxy, both giving equal performance overall.
Old 10-10-2008, 03:27 AM
Does Eastwood's Chassis Black ever fade or dull?
Does Eastwood's Chassis Black ever fade or dull if on a part of the car that is exposed to the sun or elements?
Old 10-10-2008, 11:17 PM
Well it's been awhile, but I went the 2 part epoxy primer with a urethane top coat on our '46 and IT IS THE BEST! I am very happy with it. We have a two year old now who "helps" me in the garage a lot and he has used the jeep frame as a chalk board, a shelf for anything leaky and sticky, and even as a piniata with his little metal hammer and some rocks, and he has yet to chip or damage the finish. I am pretty impressed. If it stands up to him, it should have a much easier life on and off road.
As an aside, I have a second plow jeep that has a lot of parts painted with the Eastwood Chassis black and it is clearly not as as durable of a finish. And, comparing the costs of 8 cans of eastwood paint to what I was charged for the urethane finish, I feel the urethane will be a better long term value.
34 Ford - Title stay with chassis or body? heyjude076 General Rodding Tech 3 05-28-2007 06:27 PM
First stage of rebuild, chassis first? Oz GMHR General Rodding Tech 6 06-26-2005 11:36 AM
51 merc chassis options?? 54 Chevy Suspension - Brakes - Steering 7 02-20-2005 10:59 PM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 06:50 PM
Stretch or custom chassis deleteall General Rodding Tech 5 04-23-2004 02:51 PM
