Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chassis # help please
Old 03-17-2013, 02:38 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
What are you working on / building? Also, for a safety factor, your steering idler arm bracket is not mounted to anything too strong. I would be very scared of that one. You need more support since so much has been cut off. Are you reading a number on the original frame part or the subframe that was put on?
