Chassis Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2013, 02:51 PM
Chassis Problem
Hello Everyone,
I need help with material selection for my chassis. I am coilover mounting tabs and motor mounts from plate steel and I have a design but what thickness mild steel should I use.
I was thinking about 8-10mm thick but would this be overkill and should I go with 6mm, price is not an issue but it must be mild steel.
Thanks
Old 06-29-2013, 05:09 PM
BOBCRMAN@aol.com's Avatar
Your question needs a lot more info before any realistic help can be given.. Wheelbase, curb weight, frame width and length. Intended use. Main rail width/depth?
Old 06-30-2013, 06:43 AM
Curb weight is 1000kg, 103 Inch wheel base, standard model frame width and 6 inch longer length at rear. 6 Inch Z in front 12 Inch in rear.
Old 06-30-2013, 07:13 AM
Wiki Edits: 27
engine-trans
Also engine and trans weight. a 1. 6 liter 4 , or a CAT diesel ?
Old 06-30-2013, 09:33 AM
Engine is small black ford with t5 transmission
Old 06-30-2013, 10:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use 3/16 myself..how that translates to mm dunno right now..
Sam
Old 06-30-2013, 10:50 AM
life is a temporary assignment
A lot of things goes into play when building these things,, What type of tabs and motor mounts you will be building,,, There's ways to use 3/16 And different ways to use 1/4,,, So without knowing how you plan to do the mounts and tabs,, Hard to say,,, It has a lot to do with your welding skill's also..
Depending on how I make mine,, I usaully use 3/16...Or tubing,
There's all kind of ways to build Mounts and tabs..
Here's something that might give you some ideas on tabs and motor mounts..
Making A Willys Frame !!
New Homemade Ratrod In The Making!!!
Building A Homemade C-cab !!!
Old 07-02-2013, 05:15 PM
327NUT's Avatar
Here's some pics of the 507" Cadillac installation after pulling the 327. I used some 1/8" plate and welded it to the boxing plates for a thickness of 1/4". The rest of the mount material is 1/4", could use 3/8 but that is probably overkill.
The tig welding was done outside during a breezy day so it's not perfect but it is very strong, drilled 4 holes in each plate to utilize some plug welding ....... I think most guys use 1/4" so don't get hung up on the thickness, just bevel the edges a bit and make everything is nice and clean for a good weld.
ID:	75380   Click image for larger version
ID:	75381   Click image for larger version
Old Shell and new chassis versus upgrading old Chassis custer_h Hotrodding Basics 14 04-01-2009 09:37 AM
s10 chassis vs. tube chassis penguinoitaliano Suspension - Brakes - Steering 2 12-28-2006 09:40 AM
40 ford w/ 90 s10 chassis steering problem. Pops40Ford Suspension - Brakes - Steering 5 03-25-2006 08:08 AM
having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC ChevyJim Electrical 5 01-28-2006 08:20 AM
Chassis Shields General Rodding Tech 2 02-27-2004 12:13 PM
