Chassis Saver vs Powder Coat on frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 08:24 AM
Mutt's37Buick's Avatar
Trying to decide on Chassis Saver or Powder Coat on my 37 Roadmaster frame.
Would love to hear pros and cons of each.
Thanks.
Old 01-03-2013, 10:03 AM
Faith - Respect - Trust
If you have the funds to get your frame powder coated....get it powder coated...you'll have a much better finish and more durable than Chassis Saver.
Old 01-03-2013, 01:07 PM
Irelands child's Avatar
X2
If you do a search here, you will find several discussions paint vs PC. Most of the detractors say "if you miss welding a bracket on, you wont be able to touch it up" Duh!! Do it right before you PC
I have it on my '31 and since I built it 'right' never had that problem. My only advice to anyone PC'ing a frame - black is easy to touch up if you do screw up and do gouge it - but in 4 years driving mine is still pristine.
Irelands child
Old 01-03-2013, 07:56 PM
sedanbob's Avatar
I went with powder coating - good looking durable finish. If I did have to weld something on, I'd clean that part of the PC off, then paint just that part. Overall it would still look better. Mine's gloss black.
Best corrosion protection: Chassis Saver or Epoxy Primer? Noob81 Body - Exterior 5 01-03-2012 05:26 AM
Painted frame with chassis saver but not thick enough JustBlaze Body - Exterior 9 06-17-2011 07:45 AM
Safe to Powder Coat Alum. Bicycle Frame 1ownerT Body - Exterior 2 01-01-2011 10:39 PM
chassis saver swvalcon Hotrodding Basics 1 10-14-2010 06:41 PM
Chassis Saver mattmanuel Body - Exterior 2 01-30-2006 12:25 PM
