chassis swap on a '60 Rambler American SW - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-22-2005, 03:10 PM
I'm thinking that a way to get "modern" on my "60 Rambler American SW would be to set the body on a late model S-10 chassis. Has anyone done it this way? What are the pros and cons? Thanks for you time and thoughts, RWT
Old 07-22-2005, 06:54 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Hi Roger welcome,some discussions in the knowledge base on frame swaps might help or perhaps ask your question in the suspension forum.
Old 07-23-2005, 12:22 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HR.COM
LOOK AROUND PLENTY TO ABSORB
ENJOY
SR66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 10-03-2009, 08:15 PM
Alas, all AMC and Ramblers (and Nash since the 1940's) are unibody. No frame! Just two cross members that bolt on, suspension and rear of trans.
Old 10-03-2009, 09:06 PM
Wiki Edits: 31
this thread is old..
however. AMC's and Ramblers are Unibody from the Factory BUT, they can be adapted to a chassis by removing the floor and unibody structure.. check out American Lt1's Rambler, he did just that
Old 10-04-2009, 07:45 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. ................Cole
Old 10-04-2009, 08:14 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Welcome to the site.. Great to have you here....
1960 Rambler American engine swap Ramblin' Man Hotrodders' Lounge 35 05-16-2013 08:27 PM
rambler american engine swap bnsurvey Engine 3 11-30-2011 04:10 PM
59 Rambler Wagon chassis Swap ? KozAZ Suspension - Brakes - Steering 8 12-05-2009 10:25 AM
Back up on the dyno. MK2TMR2 Hotrodders' Lounge 33 06-23-2005 01:47 AM
