Chassis Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2005, 08:14 AM
Chassis Swap
I'm new here and new to hot rodding mods. Is there any stock rolling chassis (like maverick, etc.) that will go under my 1930 Model A without extensive (expensive) modifications? I'd like to put modern running gear and a mild modern motor in my 'A' without spending thousands.
Old 12-09-2005, 08:20 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Mavericks and such are UNIT BODY cars, as is nearly every other US built car since the 1980s (with a few exceptions). The closest you're going to come is a small truck chassis. Nothing will be an easy fit, but an older Toyota or Ford Ranger might work okay -- an S-10 will be to wide. There will be a lot of modifications needed. If you're not a welder or don't have a buddy who is, forget it! The only other alternative is to buy a ready made chassis from one of the roadster builders. TCI makes one as well as many others. You might consider suspension changes to your existing chassis.
Old 12-09-2005, 09:15 AM
chassis swap
Many thanks for the tech info FARNA. Nope, I'm not a welder, although I've done some in the past years, but sounds like too much involved. Yes, I'm aware of TCI frame packages and such, and have comtemplated that, but they're like several thousand dollars. Guess I'll stick with what Henry Ford provided it with. Happy Holidays.
59 Rambler Wagon chassis Swap ? KozAZ Suspension - Brakes - Steering 8 12-05-2009 10:25 AM
chassis swap on a '60 Rambler American SW Roger W. Taylor Introduce Yourself 6 10-04-2009 08:14 AM
Chassis Swap Help! riffs3 Suspension - Brakes - Steering 2 07-28-2002 07:32 PM
57 chev chassis swap dc6902 Hotrodders' Lounge 1 07-05-2002 12:29 PM
