On the cheap 1955 4 door to 2 door
go all out and weld up both doors and have one long door .
or you can get the two door doors and a door jam and make up a two door . hardest thing will be your side stainless working out . or you coul cut out the whole body section and build a shorty shoe box like allot of builders try . |
Lets cut it up has turned a 4 door into a 2 door.I would shave rear handles but not fill seam. A 4 door without rear handles looks OK. With the back seams filled it will look funny with the short front doors. IMHO.
Its been done.........but you need the parts from a 2 door, so why not just look for one........unless you can find the parts without stripping a 2 door.
Ontario Rodders |
like i said "until i install some 2 door doors" I know the process to do it right but i just wanted to see some 4 doors with the door handles shaved for now or and the seams filled..ill even cut out the rear window post and use plexiglass,, and the car was given to me free,, sooooo... any pics?
Here's the '57 I converted in the early '90's. I just welded the rear doors shut, slapped on some filler, primed and painted. Definitely an "on the cheap" affair. I used a set of Honda buckets and you could squeeze into the back seat if you worked at it.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
I had a 55 years ago that I just removed the rear door handles; it looked fine(considering it wasn't a 2 door). You said you were on the cheap. Any other way, you're at least going to get into a bunch on work. You can't just bondo up the seams; the vibration of driving will crack it out for sure.
If you weld up the doors, you're going to get into having to get special seats, or eliminate the use of the back seat. Actually, in today's world, 4 door performance or sporty cars are commonplace (like the Dodge Charger or SRT8), and many rodders have gone to 4 doors, simply because they're more reasonable to buy and more plentiful. I'd think about taking all the door handles off and replacing them with late-model body color units, like from a Firebird or Neon, and leave it as is. That'd be the cheapest way. |
Leave it a four door until you can do it right, If you weld up the doors you will have all kinds of double work on your hands to open them back up to get to the meat of things when you want put in the right length doors. Just shave the handles and run like that. JMO Tim
buggmann
I HAVE HAD A COUPLE OF 4 DOORS YOU CAN SHAVE
THE HANDLES IF YOU DO IT RIGHT IT WILL LOOK GOOD TILL YOU CAN DO IT THE WAY YOU WANT TO DO IT THAT WAY IF YOU CHANGE YOUR MIND AND YOU GO TO SELL THE CAR OR YOU DON'T MAKE IT A TWO DOOR IT WILL BE LESS WORK IN THE LONG RUN
I seen this '55 4-door a few years back at Columbus Goodguys and it really looked great!
![]() I am on the look out for a clean 4-door to shave and paint black to hide the door gaps...... Last edited by cyclone-rods; 07-03-2008 at 12:30 PM. |
| '36 Ford door alignment saga continues... | flynbrian48 | Body - Exterior | 0 | 11-28-2007 06:56 PM |
| Door alignment problem | 58Apache | Body - Exterior | 4 | 10-06-2007 12:22 AM |
| body parts fitting | anyoldchevy | Body - Exterior | 10 | 02-20-2005 09:20 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
