Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheap 1k Sealer Primer
Old 01-25-2013, 11:31 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
To be on the safe side....I wouldn't use 1K anything...like Brian said, it's a weak link in the chain....I liken it to making a ham sandwhich with rotten meat. Your metal is a solid piece, your clear is a catalyzed top coat and what have you got in the middle???? If it's worth doing...it's worth doing with materials that work well together and the cost difference between a 2K Epoxy and your 1K sealer is minimal....use a good 2K sandable Epoxy, prep it and paint it and you will have a better result and you know in your own mind that it's done properly...if you where sure about the 1K sealer, I don't think you would have started the thread, so if you have doubts (and your doubts are justified) use a catalyzed primer.
Ray
