cheap 5 speed swap option? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2006, 11:41 PM
I found a wrecked 95 chevy v6 p/u with a 5-speed manual transmission in it. I was told that it will bolt up to my 383 without any mods, other than a new clutch....
Would this be a good idea or not? How long will this trans hold up to my torque and most importantly, can a shop re-build it to handle a lot more power in the future?
thanks,
sean
Old 06-03-2006, 10:11 PM
My Father did the same thing on his 69' C10 350.He babied it till he could afford a doug nash off ebay.It lived.Most shops could rebuild it stronger,But I really don't think they could build that trans strong enough for your application.I would do it.But I would'nt wrap it up too much.Till you could afford a stronger trans.Like a Doug Nash,a Tremec,or a Richmond.It also depends on what you have in your truck now.Wheter it's the smart thing or not.I'd do it and keep your other trans just in case.
Bonzipenguins
Old 06-04-2006, 11:43 AM
The only way I think I could do it is if it could be rebuilt to the strength of a Richmond or Tremec. If that isn't the case, then it isn't worth the swap since my motor makes more torque than horsepower... and I hear that torque is what tears up a standard transmission.
Old 06-06-2006, 03:44 PM
I'd wait and save for a richmond,tremec,or a Doug Nash although I hear the've been taken over by u.s gear.My personal favorite was the Tremec TKO trans.It was almost $2,000.00 but I could'nt break that with a 509ci bb in my 69' camaro.awesome trans.Good luck
Bonzipenguins
Colorado\Canyon 5-speed swap Greg55_99 Transmission - Rearend 1 06-12-2006 08:34 PM
272 y block swap gspector Engine 5 06-26-2003 12:04 AM
1991 chevy 4wd V6 swap to V8 Michael Breaux Engine 3 10-20-2002 02:48 PM
235 Engine / Powerglide to 3 speed swap New2theart Engine 2 07-16-2002 06:22 PM
