Cheap carb comparable to a #3310? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2005, 10:51 PM
hcker2000's Avatar
Basicly I can't find a holly #3310 for a decent price so are there any other carbs with comparable goodness that are easyer to find and just as cheap?
Old 06-25-2005, 11:42 PM
lluciano77's Avatar
Get the 750 CFM Holley model 4010. It has annular boosters. They are on Ebay every once in a while. Usually for about $25 to $100.
You will get better mileage, 50+ more ft./lbs. of torque, and more power.
Old 06-26-2005, 12:04 AM
hcker2000's Avatar
Humm I will keep an eye out but these seem to be as hard to come by as the #3310's.
Old 06-26-2005, 01:49 AM
GoneNova/406's Avatar
when looking for 3310's you won't find another carb on the planet thats more plentiful except the quadrajet, but the carb to look for and have if you can find it is a 3310-1,it is a 780 with high performance down leg boosters.it was started at GM in 1965 on the 396 motor.the rest of the 3310's are 750's with straight leg boosters and a half pipes.still a good carb but not equall to the 3310-1.the rebuild kit for 3310-2,3310-3,3310-4, is about 25.00 but the 3310-1 is about 85.00.get the kit for -2,the -1 has stuff in it for many different carbs from the car manufacture's that have a very slight difference's on them so that when you're through with the rebuild you will have left over parts.instead just get the kit for -2,3 or 4 and you may have to buy one or two parts separately but they will not come close to 85.00.most knowledgeable carb people have high praise,s for the 3310-1.also it is the only 3310 carb that comes as a 4150 carb to begin with.i have all of these carbs mentioned and all but the 3310-1 have to have the trick conversion kit added to convert them from 4160's to 4150's.i am not saying the rest of the 3310's aren't any good, the -1 is just the better of all of them and i am infact using the 750 on my motor now.
Old 06-26-2005, 02:00 AM
hcker2000's Avatar
Yea I had heard of the 3310-1 and its greatness. I just wish I could find any of them. No chance you would let one of your #3310's go (dosnt matter which)?
Old 06-26-2005, 03:31 AM
what do you have for a carb now?if you are able to put one together i think i almost have enough parts to make a complete carb.i think i would be missing the bowls.i 've got a -1 and two -2's apart overhauling them now but i'm not going to be doing it all right away.have other pressing matters first but like i said i think i will still have enough parts minus the bowls.the main body of this carb may need to be blasted though.when i was cleaning these carbs that body did not clean up like the others.rebuilders blast them then recoat them.don't know how exspensive it would be.i may have a 650.how big of hurry are you in?i just noticed you're in ohio too.
Old 06-26-2005, 03:43 AM
hcker2000's Avatar
Yea I noticed you were in columbus after I posted the last message. I'm about 30 min from columbus.
Currently I have a 350 that I'm rebuilding and have no carb for it so no huge hurry. I could probably find a doner carb on ebay for the bowls. Only thing I don't know about is how I would assemble it. I'm generaly fine putting them together if I take them apart but never put one together from just parts. I'm not sure how much you would want for one but if your willing to part with that -1 and it wouldent be to much for my 350 then send me a pm and let me know what you would want for it.
Old 06-26-2005, 08:02 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
I have a 3310-2 in a box in the basement. It was running rich when I removed it from a 383, may need to tweek it for your application. How about $100.00 and you pay shipping?
Old 06-26-2005, 11:23 AM
lluciano77's Avatar
The 3310-1 sucks. I have a few of them trust me. The downlegs boosters kill all of your streetable power. Like I said, get the 4010 750 CFM Vacuum carb. It will run better than any other Holley, any Quadrajunk, and almost all of the BG carbs.
Read the new Car Craft magazine article about Annular boosters VS. downleg boosters. The downleg boosters lost 94 ft./lb of torque @ 1,800 RPMs compared to the annular. That is where you need the torque most for a street engine.
Old 06-26-2005, 11:26 AM
lluciano77's Avatar
http://motors.search.ebay.com/holley...fsopZ1QQfsooZ1
There are a million 3310-1 out there. Let someone else make the mistake of bolting one on their engine.
Old 06-26-2005, 12:12 PM
Mustangsaly's Avatar
what holley would i want on a victor jr. intake on a 383 ? a dual feed, vacuum secondary electric choke carburetor square bore ? or a mechanical secondary electric choke square bore ?
Thanks
Mustyangsaly
Old 06-26-2005, 01:30 PM
lluciano77's Avatar
There are a lot more things you need to take into consideration than what you listed below.
With what you gave me I would go with a mechanical one, 650 CFMs or larger. How much larger depends on compression, gear, stall, cam, etc.
Old 06-26-2005, 02:11 PM
i like the 9.3:1CR in the set ups below, so probably 9.3 10.25:1 CR with 373s and around a 2700 stall with 76cc heads, these set ups show 750 DPs.
Displacement: 383 cu. in.
Carburetor: Holley 750 double pumper
Heads: GM #441 castings, 76cc chambers, 2.02/1.60 in. valves, pocket ported
Intake: Edelbrock Performer
Camshaft: Comp Cams 280? Magnum hydraulic, with 280/280? of duration, 230/230? of duration @ 0.050 in. lift, and 0.480/0.480 in. lift
Rockers: 1.5:1
Headers: 1 5/8 in. street
Pistons: TRW forged
Rods: 5.565 in.
Crank: cast
Comp. Ratio: 9.3:1
MAX HP: 382 @ 5300
MAX Torque: 400 @ 4500
Camshaft: Comp Cams 292? Magnum hydraulic, with 292/292? of duration, 244/244? of duration @ 0.050 in. lift, and 0.501/0.501 in. lift
Rockers: 1.5:1
Pistons: TRW forged
Rods: 5.565 in.
Crank: cast
Comp. Ratio: 9.3:1
MAX HP: 399 @ 5700
MAX Torque: 399 @ 5000 and 5500
Intake: Edelbrock Victor Jr.
Camshaft: Comp Cams 280? Magnum hydraulic, with 280/280? of duration, 230/230? of duration @ 0.050 in. lift,and 0.480/0.480 in. lift
Rockers: 1.5:1
Pistons: TRW forged
Rods: 5.565 in.
Crank: cast
Comp. Ratio: 9.3:1
MAX HP: 400 @ 5700
MAX Torque: 403 @ 4500 and 5000
Old 06-26-2005, 02:22 PM
lluciano77's Avatar
Run a Performer RPM Air Gap intake with the annular 750 Holley DP. You will have excellent bottom end torque and driveablity.
If you go with the Victor Jr. you will loose some of that bottom end. I don't know how much the annular carb will bring back. It should bring back some of the street manners.
Old 06-26-2005, 09:24 PM
hcker2000's Avatar
I was also considering the air gap but here in ohio I don't think it would be a good pick because of the cold winters.
I will look into the 4010 as well.
EDIT:
No wonder I couldn't find any I was spelling holley wrong lol.
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
'86 GMC carb problem johnnymopar Engine 3 10-22-2004 02:29 PM
Demon Marine carb. help musky2 Engine 3 10-19-2004 11:16 PM
1 inch carb spacer black66 Engine 6 09-04-2003 06:21 AM
Where can I find this carb? (QJet) 78SilverShark Engine 7 08-14-2003 03:07 PM
