cheap ford 9 inch housings for chevys - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2003, 11:26 PM
where can i find 1 for a g body(monte).need housings and axles,the cheapest i found is$675
Old 08-05-2003, 11:49 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
http://hiqties.hypermart.net/9inch.html#housing check this site for info, unless its something hi-performance you're looking for.........joe
Old 08-06-2003, 12:40 PM
thanks anyway but i want a 9 inch housing with control arm brackets all ready welded on to fit into chev g body car(monte)
Old 08-06-2003, 12:46 PM
EBlack36's Avatar
Rebuilt Excitment
You will more that likely have to go with someone such as Currie to get one with the brackets already installed.
Old 08-06-2003, 01:56 PM
found one at quick change for $675 for housing and axles.Just want to find one cheaper.
$675us dollars=$100000000000 canadain
Old 08-06-2003, 02:09 PM
'67Pony's Avatar
Dancin' to Heavens Door
Is there such thing as a cheap Ford 9" rear end? LOL I found a fellow on eBay selling a "Ford rearend" with a starting bid of 100.00 and no reserve. It happened to have come from a '69 Cougar. This peaked my interest knowing it would bolt right into my Mustang. When I looked at the one photo he had posted I noticed it was a Ford 9"-er...I was stoked. I got the rearend for 100.00.
My point is that you 'could' find a similar deal and get it cut down and modified for your Chevy for less 675. I was going to do that and found for about 189.00 I could get the housing and axels cut down. If it has a 31 spline axels...they usually won't cut down the 28 splines because they are tapered. The cost was less for just the housing. Also, many of the older Ford F150 and larger series pickup trucks have 9" rearends.
hope that helped a little
GB~
Old 08-06-2003, 02:16 PM
willys36@aol.com's Avatar
Wiki Edits: 21
$675us dollars=$100000000000 Canadian
Tell me about it. My wife just won an auction on ebaY and thought she was paying $65. Turns out the seller is a a Chanuck and it will cost $95US!!!!
I have a complete 9 inch from a 71 mustang with 3.73 posi would this be a 31 spline . WHATS A EASY WAY TO FIND OUT
Old 08-06-2003, 02:36 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
pull out the axel and count the splines...
Personally, $675 for a 9" that's ready to bolt on sounds like a great deal to me, unless I'm getting confused again...
Old 08-06-2003, 02:40 PM
'67Pony's Avatar
if I'm not mistaken...the 28 splines have two holes/caveties cast in the end near the lug holes and the 31 spline have one large oval shaped hole/cavety cast in it....just double checked...thats correct. Just look and the exposed end of the axel. oval hole=28 two round holes=31.
Old 08-06-2003, 04:22 PM
Wiki Edits: 21
Great tip, thanx! Now watch me use that to make an expensive decision some day and have the only exception that Ford made! MURPHY LIVES!!!!
Old 08-07-2003, 03:36 PM
Are you sure you want a ford 9 inch? in my opion the 9" is way over rated a good 8.5" 10 bolt chev should serve you nicely any why spend more money that you have to. Or if you must have a real stout rear end consiter a dana 60
Old 08-07-2003, 04:54 PM
Wiki Edits: 21
Are you looking for one already set up for your specific car? If you can do a little welding and fabrication yourself, you can get the complete rear end including third member/gears, brakes, axles & housing at Pick-A-Part, usually for $100 or less then adapt it to your car.
Old 08-07-2003, 06:51 PM
I can't find one the proper length,so then i would have to cut one down.For the difference in money i figured i would just buy a housing already set up so i have no problems.I spent all day on the net trying to find a package cheaper than $675 and close enough that shipping isn't going to kill me.Does anyone know of any good sites.
Old 08-07-2003, 09:08 PM
dmorris1200's Avatar
doesn't play well with others
Oh yeah, overated. It's only been one of the most widely used factory rears in everything from Street Rods to Bracket Cars. I'll bet you don't even know what makes the 9inch rear so desirable.
BUILT FORD TOUGH
