This is my hydraulic stacker that I use as a worktable, body lift, and for loading heavy stuff into my truck. I modified it by welding some square tubing to the forks, and I made some extensions out of smaller square tube. I can adjust the length of the forks or remove them to use it as an adjustable height table. The capacity is reduced the longer I extend the forks but its capacity is 1800 Lbs lifting straight up with the factory forks, so there is no problem lifting my coupe body, it also rolls very easily, and does'nt take up any more room than a small table when rolled up against a wall. One of my most useful garage tools that I purchased off a local farmer for 90 Bucks.
