Cheap multi use lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2011, 11:07 PM
This is my hydraulic stacker that I use as a worktable, body lift, and for loading heavy stuff into my truck. I modified it by welding some square tubing to the forks, and I made some extensions out of smaller square tube. I can adjust the length of the forks or remove them to use it as an adjustable height table. The capacity is reduced the longer I extend the forks but its capacity is 1800 Lbs lifting straight up with the factory forks, so there is no problem lifting my coupe body, it also rolls very easily, and does'nt take up any more room than a small table when rolled up against a wall. One of my most useful garage tools that I purchased off a local farmer for 90 Bucks.
ID:	61001   Click image for larger version
ID:	61002   Click image for larger version
ID:	61003   Click image for larger version
ID:	61004   Click image for larger version
Old 12-22-2011, 09:25 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
that is a cool tool
everybody should have one
Old 12-23-2011, 03:12 PM
Semper Gumby
Wiki Edits: 2
Stacker
I have one of those and yes I use it for lotsa tasks. I also just acquired a bunch of pallet racking for storing stuff (in an effort to reduce my "trails around stuff/have to climb over stuff to get around in the shop" habits)
I have NO idea how I ever got along without it. Load stuff into/out of pickup, stack stuff, move stuff, pick up the garden tractor to service the blades, put new compressor pump onto the tank, etc.
Mine has a 5,000# capacity, and I paid $300.00 for it from a liquidation sale when a warehouse was closing
Old 12-28-2011, 02:06 PM
bob491's Avatar
old biker,rodder,gunner = oold
good work
Nice going Jim this is what rodding is all about.
Bob trapped between the lake and the 401
Old 12-30-2011, 07:57 AM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
That is too cool- i want one for home.
Old 12-30-2011, 11:57 AM
dinger's Avatar
It kind of reminds me of the small, one person standing forklifts. If these get sold used they would be very cool in a shop or paved area. http://www.google.com/search?tbm=isc...w=1076&bih=626
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Multi Carbs for 454 Southern Pride Hotrodding Basics 6 02-05-2009 02:19 PM
2.8 multi port chevrolet327 Engine 7 09-06-2007 09:40 PM
Cam Lift verse Rocker Lift, SBC Sky65 Engine 3 11-04-2006 05:15 PM
BC/CC multi color multi color w/stripes ? LanceM Body - Exterior 6 07-18-2005 07:27 AM
Cheap spring lift 5.0Falcon Suspension - Brakes - Steering 2 12-21-2004 07:09 AM
