cheap powder coating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 10:08 AM
scheetz93's Avatar
hello all, been surfing ebay and i came up on some powder coating setup for any where between $75-140. How well can these work? Eastwood even has one for $100
thanks
Old 05-07-2005, 03:42 PM
mitmaks's Avatar
Last journal entry: Grille
ive got one of those, theyre fine for at home powdercoating, the problem is to find oven to cure your parts
Old 05-07-2005, 09:07 PM
A/G WILLYS's Avatar
I bought one of the yellow ones on ebay and it works perfect, I did numerous sets of wheels, a-arms, exhaust systems, no problem, as a matter of fact my friend had one from Eastwood and liked mine better, said the powder stuck better and I was able to put 2 coats of powder where his wasnt powerful enough to do that as far as the oven I went down to the local appliance store and took home a freezer they were throwing away and a stove and put the elements and controls from the stove into the freezer and it works great, I took the baking rack out of the oven and hung it in the top of the freezer and used that to hang my parts, I put a whole exhaust system in it and baked it at one time. I started with 2 oven elements in it and found one worked better, one thing with powder coating make sure that your edges are not sharp powder doesnt seem to coat a sharp edge and only promotes rust and once the edge starts to rust it works it way underneath the powder coat and causes it to flake off, good luck. Dave
One more thing the high temperture powder coating is not perfected and doesnt work too good as of yet.
Old 05-07-2005, 09:44 PM
scheetz93's Avatar
thanks for the info i will look into geting one off ebay
Old 05-08-2005, 11:55 AM
BarryK's Avatar
I have herd negative things about the cheap powder coats.
We have two experts from the powder coating side on here Powder Bill and GMW, sure they will be on soon and would wait for their recommendation.
Old 05-08-2005, 01:24 PM
Last journal entry: Suggestions worth sharing
I have also heard some negative comments about cheap powder guns charging efficiency compared to "name brand" guns, BUT two things to consider:
-I have no direct personal experience with those guns, so the negative comments that I'm passing on is strictly heresay.
-Even if the charging efficiency is reduced compared to a top of the line gun, one can likely overcome that for home use to a large extent by simply preheating the part slightly. That's what the industry typically does for non-conductive or marginally conductive substrates like mediun density fiberboard. Depending on just how good or bad the gun charges, a part temperature anywhere from 130 F to 200 F when spraying should let you get decent film build, even if the electrostatic wrap or faraday penetration isn't optimal.
Bottom line, even if the charging characteristics of the cheap guns isn't so great, for most of us the alternative is wet spray liquid with *Zero* electrostatics, so even a bad powder gun may not look so bad in comparison.
Old 05-08-2005, 09:12 PM
scheetz93's Avatar
what is all involved in powder coating? Do i need to take the part down to bare metal.
What else do i need to know befor juping in?
thanks
Old 05-08-2005, 09:15 PM
Bill, Yahoo has a translator for Spanish to English, German to English and so on, but they don't have one for Engineer to bodyman, what the heck is "electrostatic wrap or faraday penetration". I believe I understand it, but what is an explaination in normal english?
Old 05-08-2005, 09:23 PM
A/G WILLYS's Avatar
Holy smokes my head is spinning,,, you cant powder coat over paint, grease, rust, everything should be sandblasted before coating for best results and adhersion.
Old 05-08-2005, 09:51 PM
Brian, electrostatic wrap is the ability of the powder to wrap around the backside of the part being coated. It's one reason that powder works well for coating complex shaped parts. For example, I recently coated some A-arms made out of DOM tubing. Within limits, I could spray the front side and simply allow the electrostatic wrap to coat the back side of the part. It helps give more even film deposition and avoid bare spots.
Faraday penetration is the ability of the powder to coat into recessed areas. Imagine, for example, an open coffee can that you are spraying into. (A so-called "Faraday cage".) The electrostatics will tend to coat the front part of the can well, the back part of the can fair, but the corners with difficulty. (Like most things in life, electrostatic spray has both its upsides and its downsides.)
Sheetz, its generally best to apply powder to bare metal (or better yet, phosphate pre-treated metal). While some liquid finishes can be topcoated with powder succesfully, many can not, so without doing some experimenting it's hard to predict the outcome. There are some previous threads on this site that go into more detail about the powdercoating process, including some in the knowledge base. Powder coatings are well suited to things such as wheels, suspension components, underhood components, even complete frames if you have a large enough oven. Exterior body panels are possible but probably not the best choice for the home hobbist. If you can't bake it to metal temperatures of 350 F to 400 F, then powders are less of a fit.
Old 05-08-2005, 10:25 PM
Thanks, I now a few words I can baffle them with at work. I was on the right track with the electrostatic wrap but missed the Faraday penetration a bit. I figured it had something to do with film coverage but didn't thing it that exact type of coverage.
Old 05-11-2005, 08:29 AM
RC custom from hell.
I usually take my stuff to a local coater. If something is not right they redo it for no charge. I have been tempted to get a kit, but most stuff I want done is bigger than any oven I could afford.,,,,RR
Old 11-29-2005, 08:05 PM
nissan's Avatar
Last journal entry: 1930 chevy ratrod pick-up
nissan
thanks
get an electric range"don't take your wifes" get a good earth ground. or buy some infrared lamps an build your own oven. I know people who have had sucess with these. I work for a powdercoating co in Franklin PA or I would build my own.
Powder coating Engine Chadwick Engine 4 11-26-2005 08:31 PM
Powder Coating Kit hz350 General Rodding Tech 4 04-13-2005 10:30 AM
powder coating auot body ELECTROBE Body - Exterior 0 07-24-2004 12:09 AM
Powder Coating - Tecnical but not auto related Native Gearhead Hotrodders' Lounge 2 02-19-2004 06:55 AM
Powder coating vs. chrome Busted Knuckles Body - Exterior 13 01-21-2004 01:32 PM
