Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheap power Conversion
  #24 (permalink)
Old 12-13-2012, 03:20 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Originally Posted by Yachtsman View Post
If you mean ethanol is hyroscopic it is it won't mix with gasoline unless it's chemically dried. Chemically drying ethanol is very expensive and very energy intensive and quite pointless ethanol fuel burns well enough with 2% water in it. If you leave E85 in an open container it will absorb water from the air and the gas will separate out. once its got that 2% its happy. In Brazil they sell ethanol 2% water (Alkohol in Portuguese) in every gas station and it's cheap really cheap.
Now if you can just get sugar cane to grow in the uk and your set.
Cars in brazil run like *****... Ethanol is not a good fuel for hp or milage. Its only the next cheapest thing to oil. Most race cars run methonal which has some very unquie properties. The more water ethanol picks up the thicker it flows and the leaner your engine will be. You can only jet for one type of fuel too much water and it will start to effect performance.
