Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheap power Conversion
  #27 (permalink)
Old 12-13-2012, 04:40 PM
hcompton hcompton is offline
Old & Furious
Originally Posted by Yachtsman View Post
The days of petroleum products like petrol/gasoline being the cheapest fuels to use are gone, its time we all manned up, crude oil is running out. An engine can be built that has the HP and do the mileage of a petrol engine. Most of the tuning tricks that have been learned with petrol engines. petrol is just a mixture of random organics. We can easily put a blend together a mixture that is cheaper than petrol has been for years.
Bio desiel is the only one that will work and can be done at home since no store or gas station sells this mythgas you speak of.
Methanol is easier to get than ethanol and is cheaper but has less energy density. But you can atleast get your local heating oil company to bring you a few barrels eveymonth since it a by product of oil production. Usally burnt off as waste or used for low heat fuel but it does not produce enough heat to be usable as heat source for most applications. But will allow you to run 13:1 compression or higher if setup correctly. Also has the added effect of evapoating and cooling the intake can carb to the point the sweat like a ice cold glass.
