Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheap power Conversion
  #28 (permalink)
Old 12-13-2012, 06:37 PM
gearheadslife gearheadslife is offline
Banned
Originally Posted by Yachtsman View Post
The days of petroleum products like petrol/gasoline being the cheapest fuels to use are gone, its time we all manned up, crude oil is running out. An engine can be built that has the HP and do the mileage of a petrol engine. Most of the tuning tricks that have been learned with petrol engines. petrol is just a mixture of random organics. We can easily put a blend together a mixture that is cheaper than petrol has been for years.
not this b/s again.. wasn't we to run out in like 85 and then it was like 97,
then 2004, come on..
ethnol takes more energy to make than it produces.. a fuelcell.. can get it's fuel from water.. and when you take the fuel out you still are left with 100% water.. and the emissions is water.. ethnol is a fools game.. even use'n ethnol to heat the sugars to make ethnol. it takes more fuel to go through the prossess to get ethnol.. than you make.. 1/2 acre of crops makes 22-26 gallons of ethnol.. but you'll burn 37-42 gallons try'n to make that 22-26 gallons.. not very bright.. and wastefull..
