At the shop i used to work at we used to use ppg ncp-271, anytime we had something small that needed priming (like a door ding) we would just mix up a tiny bit and ROLL it on.
In fact, we had some spots where we brushed it on to get extra thick coverage, and the day we had a broken air compressor EVERYTHING got rolled ... including a hail job that needed a leopard print primer job. Worked perfect every time and requires ZERO masking (except for things your roller might bump into) |
The thing to remember about what is being said here is... Sometimes things will look good when you put it on,,,,BUT and that's a big but.... When you come back over it with other paint's.. It will sometimes cause the primer to let go under the paint..... Then your nice paint job is shot !!!! I have also leaned and life (the hard way) That just because something cost more then the others , Doesn't always make it better.... You came asking a Question, And many here gave you some very good answers... I'm the first to say.. I'm by far a pro Painter.... But I have messed around with some paint and some of my friends are the best in the business... And I have listen to EVERYTHING they had to say good and bad about what can go wrong... You won't always get the answer your wanting to hear... But you will get a answer from this site..... There is some pro painters here,,, And know what they are talking about..... Now if you do go the way you want too... Just remember later IF something goes wrong.... You were told about it... And remember it will work find today and maybe a year or two from now,,,,Or as soon as you paint it, It can come back to bite you... Your choice from here... Good Luck..
Hey Man... it's all good...
Plastic Bumper Paint
You can get rattle can paint from 5-Star Race Bodies. It is an etching primer for plastic. I have used it 100 times on Plasticized nose pieces. The key is you have to make sure you scuff the plastic to keep the primer in place under the paint when the paint starts to dry and shrink. I used PPG single shot color, as it did not like the base clear set up.
I have a great NAPA store that will put my paint in rattle cans so I can touch up wrecked cars at the track. Works great but costs about $7ea for the good cans. I have also used some PPG 2K primer in a rattle can. I think it was about $12 can but it worked great. I have a couple compressors and paint guns and I am not expert at all. Sometimes it is convenient not to have the prep and clean-up that all that other stuff requires. |
If you read the directions on those rattle can primers almost all of them will say the same thing. "Spray over a base coat." Base coat is epoxy. Just go get a quart of epoxy, mix up a little, maybe reduce it then roll or brush it on. In the long run it's cheaper than rattle cans and tons better. Don't forget the wax and grease remover.
| Cheap-ish Paint Job- Spray can? | Torque454 | Body - Exterior | 11 | 04-16-2010 04:53 PM |
| cheap spray gun | bentwings | Body - Exterior | 4 | 04-28-2009 07:32 PM |
| cheap primer | 1969f-100 | Body - Exterior | 53 | 07-16-2008 08:53 AM |
| can i spray epoxy primer over etching primer without sanding? | wickiewicked240z | Body - Exterior | 1 | 08-29-2006 09:07 PM |
| 5.5 HP Sears 30 Gallon Compressor -- Proper (cheap) spray gun for FeatherFill? | treeman | Body - Exterior | 5 | 12-16-2005 10:04 AM |
