Cheap Temporary work surface. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 06:50 PM
ComingApart's Avatar
Hey guys, need some suggestions...
Due to circumstances beyond my control, I'm forced to do alot of work on my current project sans shelter. So basically what I'm wanting to know is, what would be a good temporary ground covering I could put down in my back yard to put my car on so I can work on it. I tend to have a soggy backyard, so thats a concern. I want a surface solid enough I can jack the car up and rest it on jack stands safely.
I was thinking about just throwing down some sheets of plywood with some tiype of moisture barrier underneath and suffering with that, but I'm open to any suggestions you guys may have.
Keep in mind this is only temporary till I can get my shop space back, and the cheaper the better....
Old 05-30-2005, 07:20 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Please be careful working with jack stands on any thing other than concrete.
A lot of local track racers are used to pitting in a non-concrete area. Something commonly seen are jack stands with a 1/8-inch plate welded to the bottom of the stands for added support.
Old 05-30-2005, 08:24 PM
Already done, I started doing that years ago when all I had to work on was a gravel driveway.
Good suggestion though.
Old 05-30-2005, 08:27 PM
poncho62's Avatar
Wiki Edits: 5
Get a bunch of 24x24 patio stones and put them down.
Ontario Rodders
Old 05-30-2005, 08:40 PM
staircasesurfer's Avatar
alex p
Last journal entry: AHH
thats what i was planning to do, i all ready got the stones
Old 05-30-2005, 08:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
horse mats
The mats that are used in horse stalls work well for an outside work area..best if the area is leveled.. Lay the mats down and they will support a floor jack..they are a heavy recycled tire material..
OMT
Old 05-30-2005, 10:42 PM
Use old wheel/tire assemblies to keep the car off you in case the primary support system fails. And NEVER trust a cinder block.
Old 05-30-2005, 11:38 PM
alex p
bad experence???
Old 05-31-2005, 08:16 PM
Yep. Worked a few hours under a '65 Ford on cinder blocks one day. The passenger-side block collapsed during the night. Things that make you go "Hmmm", etc.
Old 06-02-2005, 03:03 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
there are likely a bunch of those cinder blocks (what is cinder anyway? is it concrete?) holding up your house, and mine too. Odd how they crumble under a car. but I've heard of it happeneing before.
Old 06-02-2005, 06:29 PM
AhX AhX is offline
New Member
the way they are laid out for home support creates most of the strength. remove one or 2 of those and your house would fall also.
Old 06-03-2005, 01:12 AM
Cinder = coal or other combustible, partially burnt, but not quite to the point of being ashes.
Mix it with cement like you would sand & gravel, pour it into a mold, and you get a cinder block, AKA a clinker block. Use sand & gravel and you get a concrete block, commonly referred to around here as a cement block.
Old 06-03-2005, 12:14 PM
Tazz
I remember when...
my Dad needed jackstands and used cinder blocks and 2X4's to hold up a car he wanted to pull the rearend out of...out back by the big tree in the back yard he used his come-a-long as a crain in...I wouldn't go up under the car for anything!!!
Tazz
Rat Rods Rule!
Old 06-03-2005, 12:25 PM
Hippie's Avatar
Last journal entry: HEI comparison.
The blocks under one of my '63 Impalas collapsed just as I was pulling myself out from under the car. Fortunately the wheels and tires were on it and I just got a good smack on the legs. I grabbed the bumper and pulled as hard and fast as I could after hearing a "pop" and seeing dusting coming from one of them. I just got my body clear when down she came, the back bumper caught my knees but bounced back up. Bought the best jack stands I could afford off the Snap On truck the next day. Still have and use them 28 years later.
Old 06-03-2005, 09:39 PM
Fast Orange's Avatar
Good safety equiptment always seems much cheaper after a close call,doesn't it?
lol,George
I am never going to let anybody else work on my car. onebadmerc Hotrodders' Lounge 19 12-22-2004 07:52 PM
i need to start the body work on my car montea Body - Exterior 11 11-01-2004 12:39 PM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 01:19 PM
Hey i Found Something about temporary ring fixing, to stop oil burning and smoke! 61ChevyTruck Engine 18 08-29-2004 08:27 PM
Learned behavior. coldknock Hotrodders' Lounge 19 08-25-2004 02:50 PM
