Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheapest EFI conversion possible
Old 12-13-2011, 02:31 PM
ap72 ap72 is offline
Banned
Originally Posted by TurboS10
I dont believe it is a full time job for anyone, but alot of people do commit alot of time to the "project". I suspect the group, or designers, contract with a manufacturing company to produce these units. The units are most likely untested unless you buy a completed board in which case it is tested on a test bench.
You simply need to be aware that you are not dealing with a manufacturing company directly, but rather a large network of hobbiest. So, you dont just pick up the phone and call your friendly tech support line and they walk you through why the crank trigger input is not "seeing" the hall sensor...for instance. Moreover, you are going to be working via message board or with a part time dealer to help in their spare time. This point is what made me very, very frustrated with diy efi, but I made it through.
This is one part I LOVED about DIY EFI, often the techlines for bigger companies don't know anything past "hello". There is a HUGE amount of hobbiests that know a lot about this stuff and most of them are all to eager to help out.
As far as where it is made- you can make it on your kitchen table if you like, which is about as "local" as you can get.
