Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cheapest EFI conversion possible
Old 12-13-2011, 02:40 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Originally Posted by ap72
This is one part I LOVED about DIY EFI, often the techlines for bigger companies don't know anything past "hello". There is a HUGE amount of hobbiests that know a lot about this stuff and most of them are all to eager to help out.
As far as where it is made- you can make it on your kitchen table if you like, which is about as "local" as you can get.
I believe the MS2 comes at least partially assemebled in the kit or "assembled" version, but I could be wrong. I can't imagine sitting and doing all the surface mount work unless you are very experienced and I expect they recognize this as well.
Totally agree that the tech lines can be horrible, but I just want to set up the "situation" you are in once you dive in to diy efi. It can make you feel pretty stranded at times hunting for information.
