Cheapest EFI conversion possible - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #31 (permalink)
Old 12-17-2011, 12:17 AM
EagleMark's Avatar
GearHead-EFI.com
Same thing, just differant way of doing it. Like a PC or a MAC.
If you already got a Megasquirt I would not try and talk you out of it. They are excellent. Just not the only avenue...
  #32 (permalink)
Old 12-17-2011, 12:27 AM
396375's Avatar
If it isn't fast,it isn't mine
I have an Eprom burner and blank chips cheap if anyone is interested.
  #33 (permalink)
Old 01-01-2012, 04:28 AM
Project89's Avatar
Originally Posted by TurboS10
I believe the MS2 comes at least partially assemebled in the kit or "assembled" version, but I could be wrong. I can't imagine sitting and doing all the surface mount work unless you are very experienced and I expect they recognize this as well.
Totally agree that the tech lines can be horrible, but I just want to set up the "situation" you are in once you dive in to diy efi. It can make you feel pretty stranded at times hunting for information.
the only megasquirts that are smd is the fully assembled smd versions(i.e v3.57 units).with the exception of the ms3 and ms3x expansion board these are addon boards that u cannot build urself.
these are nice because if u want to change ur ignition system input or add boost control u only have to move some jumpers around on the board instead of adding jumper wires and resitors.
the smd units are basically fully optioned out of the box
the diy units all come with a bare pcb, cpu and all the resitors chips capacitors u need to build the board urself in niceley labeld bags
an assembled ubnit is typically about 100 bucks more then a diy unit u solder together urself while i enjoyed building my first ms unit ms1 v2.2, the added cost of just buying a completly assembled and ready to go unit is worth it
as stated above deff go with a v3.0 board the boards are more heavy duty on th epower sides and can handle high or low impediance injectors without mods and when used with an ms2 or above cpu can control stepper motor iac valves.
the v3.0 board can use any of the ms cpus ms1 ms2 ms3
id also buy one of there wiring harnesses, the wires are nicely labeled to were they go every few inches down the wire, makes it really hard to miss wire something. not to mention trying to build ur own harness sucks when trying to solder wires to the db37 connector pins
  #34 (permalink)
Old 01-03-2012, 04:59 AM
4 Jaw Chuck's Avatar
People asked me why we needed this sub forum...because of threads like this!
— Han Solo
  #35 (permalink)
Old 01-03-2012, 07:21 AM
EagleMark's Avatar
GearHead-EFI.com
Hot Rodders is a dieing art with the youth of today. They are following the lines of new technoligy.
So that leaves mostly the older guys who have been around while Hot Rodding was High Tech! But the older guys are usually just not computer literate and some don't even want to learn? They would be shocked into learning if they could get to a site like this!
I'm an older guy (51) who got into computers around the same time EFI was coming into play 1989 and have combined my love of cars, Hot Rodding, and todays hot rodding, EFI !
If it wasn't for this section I would not have found this site! So I am glad it was added. Some EFI is simple to learn and old Hot Rodders have no idea how easy.
I think it is just the timing of Hot rodding of the past and Hot Rodding of today finally coming together!
  #36 (permalink)
Old 01-04-2012, 03:46 AM
It is changing, hotrodding is ever changing. Nice to see prices coming down for items like programmable EFI...and great guys like the mods in this forum to help oversee a place to discuss how to implement it.
— Han Solo
  #37 (permalink)
Old 01-10-2012, 06:32 PM
Siggy_Freud's Avatar
No kidding. I believe that anyone who can confidently learn to disassemble and reassemble a carb has all the brainpower they need to do an EFI conversion .
It's the intimidation factor that people need to get over.
Bringing history and technology together.
  #38 (permalink)
Old 01-10-2012, 06:39 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I agree.
I started with TPI to wet my feet and next will be an LS1 ECM running sequential EFI on a BBC. Hopefully I will learn the tuning too using HP Tuners.
I think alot more guys are looking at it these days.
  #39 (permalink)
Old 01-10-2012, 08:38 PM
396375's Avatar
Installing an EFI system is fairly easy if it is new and complete.Installing a factory system on a vehicle that never came with it is tougher but still doable.Trouble shooting and tunning is a whole new deal and not for the first timer.
MSD has a new system that dosn't require a return fuel line.The fuel pump pulses!The new kits are getting better,cheaper and can handle more HP every year.
  #40 (permalink)
Old 01-17-2012, 09:53 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
But you can modify your chip socket to put in a newer EEPROM so you just click erase and burn a thousand times if you want. So that is a little more work,
What do you have to do to take an older TPI, or TBI computer to convert it to EEPROM? When I say older I mean 86-95
  #41 (permalink)
Old 01-17-2012, 10:15 AM
Listen and Learn
Wiki Edits: 7
Its called Pulse Width Modulation and many factory EFI system incorporate this. I believe late 90s mustangs used it too.
Recent Modern Electronic Engines posts with photos
Vortecs on a 400 SB, the cheapest way dallam11 Engine 12 08-17-2008 04:01 AM
Cheapest 4 Link Kit.. hotrod389 Suspension - Brakes - Steering 1 01-27-2007 01:51 PM
cheapest 351 w build 82c10 Engine 1 06-14-2005 11:04 AM
Cheapest possible rod Nightfire General Rodding Tech 31 04-13-2004 10:06 PM
Cheapest Speed? manofsteel Hotrodders' Lounge 13 10-30-2002 06:59 PM
