Cheapest EFI conversion possible - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 12-12-2011, 11:08 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm looking for the cheapest EFI possible, just fuel, not timing, probably a TBI because I have several on the shelf.
I have seen units from SEFI and Meagasquirt, but I wonder if there's something real simple to do, TBI with only a TPS and a CTS, just like the Holley Pro-jection but home made.
I'm talking about building the ECM, not buying a kit, the parts to build 'em are quiete cheap nowadays, for example a 1 bar Bosch pump runs for only $30.
Any ideas please?
Old 12-12-2011, 11:45 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Megasquirt is probably the best/simplest diy project and there are alot of them running with chevy TBI's. You can rob a signal from a standard HEI distributor so fuel only works out nice. I will caution that this stuff is still alot of work no matter how easy it looks. Make sure you read the manual and hang out on their board long enough to get a feel for all the possible issues.
Old 12-12-2011, 12:25 PM
Augusto's Avatar
how much do you think the megasquirt will cost?
do they come dissasembled? I mean a bag full of resistors and stuff and an empty circuit board?
sounds like lots of fun.
Old 12-12-2011, 12:41 PM
How fast is fast enough?
Yes they come in dissassembled kits, if you go megasquirt get the MS1 board V3.0 OR BETTER. The ms1 v2.2 is cheaper but a lot more of a headache.
Fun... Only if you like the smell of flux and solder- it'll take you 6+ hours to assemble it.
I LOVE the one I am running.
BTW you can operate it with only a few sensors BUT I DO NOT RECOMMEND IT. Like any other computer project garbage in=garbage out and more sendors give you a MUCH better product, GM wouldnt spend money on them if they didnt serve a purpose.
At a minimum I would RECOMEND running a TPS sensor, MAP or MAF sensor, clt, ATS, oxygen sensor (a narrow band is fine for most street applications), and an ignition signal. You can run it with only about half of those sensors but in that case a well tuned carb would be better.
Old 12-12-2011, 12:43 PM
TurboS10's Avatar
Wiki Edits: 2
I have not "hung out" over there in years. However, at the time they had options for assembled(by members I think) boards and a bag of parts and circuit board. I know there was talk of going to surface mount so I would assume that they would do all of the surface mount stuff and have the option to finish the through hold stuff like injector drivers, but I am speculating. Surface mount is tricky and tedious, but can be done if you have alot of patience. Just go to the main site and start from there:
http://www.megasquirt.info/
Old 12-12-2011, 02:13 PM
Wiki Edits: 31
Megasquirts are available assembled and dissasembled. there available thru a couple companies..
http://www.diyautotune.com/catalog/index.php
Old 12-12-2011, 07:02 PM
Augusto's Avatar
so the megasquirt stuff is of good quality? not chineese like junk? I think I'll give 'em a try, sounds very nice.
Old 12-12-2011, 07:50 PM
Irelands child's Avatar
Agusto - Take a look at the just released MSD Atomic EFI (http://www.msdignition.com/default.a...184&blogid=429) About 2000USD, but a complete system.
Other then that, the Megasquirt is about the least expensive way to go. Their website has many, many pages for each variation along with a complete set of instructions.
I'll probably go one way or the other in the next year or so
Old 12-12-2011, 08:50 PM
Augusto's Avatar
I think I have already read like a thousand pages about the megasquirt and I think I'm in love with it, definitely will try it, thanks a lot guys.
Old 12-12-2011, 08:54 PM
Augusto's Avatar
they have a site for it alone http://www.atomicefi.com/ very very nice, I've seen something like that in the summit catalog from another company, very appealing for a classic rod with the look of a carb, very nice and I'm sure the quality is top, but 2.000 is way too much for my wallet.
Old 12-12-2011, 10:41 PM
Siggy_Freud's Avatar
The Edelbrock unit is by far not the second cheapest route. There are a number of stock to semi-stock EFI setups you could put in for 2k or under.
Bringing history and technology together.
Old 12-13-2011, 01:27 PM
TurboS10's Avatar
Wiki Edits: 2
I dont believe it is a full time job for anyone, but alot of people do commit alot of time to the "project". I suspect the group, or designers, contract with a manufacturing company to produce these units. The units are most likely untested unless you buy a completed board in which case it is tested on a test bench.
You simply need to be aware that you are not dealing with a manufacturing company directly, but rather a large network of hobbiest. So, you dont just pick up the phone and call your friendly tech support line and they walk you through why the crank trigger input is not "seeing" the hall sensor...for instance. Moreover, you are going to be working via message board or with a part time dealer to help in their spare time. This point is what made me very, very frustrated with diy efi, but I made it through.
Old 12-13-2011, 02:31 PM
This is one part I LOVED about DIY EFI, often the techlines for bigger companies don't know anything past "hello". There is a HUGE amount of hobbiests that know a lot about this stuff and most of them are all to eager to help out.
As far as where it is made- you can make it on your kitchen table if you like, which is about as "local" as you can get.
Old 12-13-2011, 02:40 PM
TurboS10's Avatar
Wiki Edits: 2
I believe the MS2 comes at least partially assemebled in the kit or "assembled" version, but I could be wrong. I can't imagine sitting and doing all the surface mount work unless you are very experienced and I expect they recognize this as well.
Totally agree that the tech lines can be horrible, but I just want to set up the "situation" you are in once you dive in to diy efi. It can make you feel pretty stranded at times hunting for information.
Old 12-13-2011, 02:46 PM
I think the cheapest EFI conversion possible would be to locate a running wrecked car with the EFI engine you want in an auction, and move parts, or do a complete engine transplant.
Recent Modern Electronic Engines posts with photos
Vortecs on a 400 SB, the cheapest way dallam11 Engine 13 08-17-2008 03:01 AM
Cheapest 4 Link Kit.. h0trod389 Suspension - Brakes - Steering 1 01-27-2007 12:51 PM
cheapest 351 w build 82c10 Engine 1 06-14-2005 10:04 AM
Cheapest possible rod Nightfire General Rodding Tech 31 04-13-2004 09:06 PM
Cheapest Speed? manofsteel Hotrodders' Lounge 13 10-30-2002 05:59 PM
