Cheapest Rear end Upgrade for G-Body GM - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2008, 04:04 PM
chevy_power427's Avatar
Fuel flows through my veins
I have a 1985 Monte Carlo SS with the 10 Bolt 7.5" Rearend. I need something stronger such as 9" Ford or 12 Bolt GM, I would prefer to keep all GM. What would be the cheapest way to go for extra durability on a street car. Used or new, what have you guys out there done??
Old 08-18-2008, 05:30 PM
montea's Avatar
tryn to learn
i have heard of guys using a 10bolt 8.5" from a earlier model Grandprix's like '77. the rear end is wider so you need to probably get different backspaced rims. drive shaft needs shortened and you have to drill out some holes bigger on the upper arms to bolt the rear end to so you get the correct pinion angle, the holes already there just farther back then the stock mounting location.
Old 08-18-2008, 05:37 PM
SSedan64's Avatar
I'm not sure which is cheapest. My guess would be the newer Ford 8.8" Mustang rear. They're cheap. Use Mustang adjustable upper control arms and the lower control arm mounts & arms + spring mounts from your 7.5" rear.
http://gbodyforum.com/viewtopic.php?p=17067#17067
http://www.cheperformance.com/cartge...st.asp?scat=71
Or 9" Ford>
http://www.quickperformance.com/Products/housings.htm
http://www.dcaracing.com/cat_9inrearend_1.html
Or Chevy 12 Bolt takes about the same mods as the Ford 8.8"
Or if you can find an 8.5" from a GrandNat , Olds 442/HO $$$
Old 08-18-2008, 05:40 PM
SSedan64's Avatar
The Grand Nat & Olds 442/HO 8.5" is a bolt in no mods and almost as strong as a 12 Bolt. Only Diff. is ring gear is .375" smaller, pinion is same Dia.
Old 08-19-2008, 05:04 AM
Last journal entry: PICTURE TEST
rear
The most economical way is to find a 8.5" grand national rear. They are a direct bolt in. The initial purchase price is on the high side for these rears, but until you do all the mods needed to make some other rear work your further ahead.
They did put a dana 44 under the "G" bodys that went to mexico. If you could find one of them that also would be a upgrade...But the 8.5" GN rear is the snizzle for you...
Keith
Old 08-19-2008, 03:32 PM
Called a place for a quick estimate, around 1600$~1800$ for a rear, used. Local speed shop sells a modified ( I believe ) 12 bolt rear that is supposed to bolt in for 2200$ Parts are new.
Old 08-19-2008, 03:59 PM
Regal Beagle's Avatar
Moser and Currie all have direct bolt ins for G Body cars. You might also want to look at "JustRearEnds.com" they have some really good pricing on their 12 Bolt and Ford 9 inch bolt ins for G Body cars.
Old 08-19-2008, 06:51 PM
BMM BMM is offline
Hit up Gbodyparts.com. Send them an email, seeing what they have for 8.5's. I know they used to even have them, complete drum to drum out of a GN, listed for 500.
Old 08-20-2008, 06:21 AM
Good luck finding a "cheap" one, however.
Old 08-20-2008, 08:10 AM
SSedan64's Avatar
Hi Joe, that's what I meant in post #3 by $$$. Should have put $$$$
Those things are like gold now. Anything to do with a GN is $$$$
BMM said $500?? More like $1500 or more now. The 8.8 Mustang rear is very cheap, just have to do your own welding for the lower control arm & spring mounts.
Kicking Rear Body ? Or Rear End? GIXXER07 Transmission - Rearend 3 08-03-2007 09:55 PM
What is the gear ratio for a GM rear end? jpd37 Transmission - Rearend 6 02-23-2004 12:52 PM
GM 8.2" rear end housings 1970SS396elco Transmission - Rearend 6 02-15-2004 02:26 AM
GM 12-bolt rear end dill Transmission - Rearend 4 01-10-2003 10:23 AM
GM Rear end identification Chuck Mulcahy Transmission - Rearend 2 11-03-2002 02:35 PM
