Check balls in 1988 Iroc with a 1982-83 model 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 07:56 AM
Check balls
Im working on my brother in laws 700r4 1982-83 model trans for his 88 iroc, we had some steel balls come out of the trans after we removed the front pump and single piece valve body with no aux. Im a jr Ford tech and could use some help in determining where they came from and where to get some as we have mistakenly thrown them out.Also one was a green plastic like ball if that helps, We also had it out of the car.
Old 01-29-2011, 07:59 AM
Old 01-29-2011, 08:31 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
mustangman... Welcome to Hotrodders.com
I merged your 2 posts into one thread here.
Did you removed the valve body 'only' from the trans case or did you also remove the flat steel separator plate too?
Check balls go on both sides of that plate.
post back when you have a chance
Old 01-29-2011, 09:04 AM
First thank you, what we did was remove the valve body to clean it in varsal vattoclean any dabris out of it and the cams. We did not remove any gaskets or the seporator plate.Does the front pump seal have any check balls in it as well?thanks for the help.
TH350 tranny check balls bodie filyaw Transmission - Rearend 13 02-02-2011 07:52 PM
T-400 check balls jlwagner17 Transmission - Rearend 14 06-14-2010 10:54 PM
700r4 check balls sbc400_700r4_3.42 Transmission - Rearend 6 12-11-2008 01:48 PM
Turbo 475 check balls Greg T Transmission - Rearend 8 07-11-2007 09:40 PM
1988 IROC Convertible.. DV8 Hotrodders' Lounge 7 05-17-2006 02:29 PM
