Check Balls In The 4l60e ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 07:59 AM
old yukon's Avatar
I received two packets of TORLON PLASTIC CHECK BALL for my rebuild.
The smaller sized check 0.25" and the larger 0.312", as I wasn't sure what I need when i first ordered.
Let see if i get this right. the 4l60e has 10 check balls.
- 2 are in capsules in the case ( #9 and #10)
- one free in the case ( #8)
- 7 in the valve body (#1 to #7).
Questions:
1. Should i replace all #1 to #8 checkballs with the Torlon 0.25" check balls ?
2. When do you use the oversized torlon checkballs in the 4L60e ? is it only on worn valve body plates?
Hope someone can help !
Old 04-26-2011, 05:49 PM
Worn Spacer Plate
There is 1-ball that is larger that others! and if kit included enough balls, would figure they wanted you to replace em! Also, You can go to a trans shop fro about 20 bucks, get a kit for the well worn ball holes. You drill out worn holes to I think it was 1/4in. then install new hardened C-clip in seats after you file down the drill high spots. The new seats are way cool cause finding a plate on a Saturday is like IMPOSSIBLE ! Kit comes with 5 new seats and c-clips, mine had 3 badly worn plate holes. Was installing a Shift Kit and went Street/Strip for my Chevy S-10 4.3. Great second gear shift, also replaced max fluid with "Trick Shift". This was Last FEB 2010, Still working great! And while your at it, Rear trans seal is A good Idea!
Old 04-26-2011, 10:17 PM
old yukon's Avatar
Thanks for the reply.
Maybe i am not making myself clear enough. 8 smaller torlon check balls came with one of the Sonnax kits. I added one additional packet of 10 larger torlon check balls because I knew i had a worn separator plate, so i thought i might need them.
I then ended up getting a new hardened transgo separator plate. Now i have a new plate and 2 sets of checkballs.
The simplest thing would be to use the 8 smaller checkballs to replace all the OEM stainless steel checkballs, right?? (that is the orange and blue circled ones on the diagram.)
You said something about an over-sized checkball ("There is 1-ball that is larger that others!...")
which one on the diagram is it ??
Do I only use the over-sized one here, and on a worn out plate if i had that problem??
Here is an additional picture of the 4L60e valve body checkbalis locations if anyone may need it in the future.
Old 04-27-2011, 08:32 PM
old yukon's Avatar
found the info i needed.
So just capping this post off, all check balls are the 0.025" unless you have a worn-out hole in an old separator plate.
Old 04-27-2011, 09:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
actually the check balls are .250 in diameter
Old 04-27-2011, 11:47 PM
old yukon's Avatar
Thanks for that Crosley, good to know someone out there is awake at this hour, a "0" missing makes a world of difference !
t-350 check balls location ? bodie filyaw Transmission - Rearend 4 02-20-2011 04:25 PM
TH350 tranny check balls bodie filyaw Transmission - Rearend 13 02-02-2011 07:52 PM
T-400 check balls jlwagner17 Transmission - Rearend 14 06-14-2010 10:54 PM
700r4 check balls sbc400_700r4_3.42 Transmission - Rearend 6 12-11-2008 01:48 PM
Turbo 475 check balls Greg T Transmission - Rearend 8 07-11-2007 09:40 PM
