Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - check brake light
Old 03-09-2002, 03:51 PM
PAULWELDIT PAULWELDIT is offline
Post
go to the proportioning valve-disconnect the wire, then un- screw the fitting the wire was connected to-recenter the pin and look to see if the notch in the shaft is in the center--if not reposition the shaft then re assemble---Paulweldit
