Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - check brake light
Old 03-25-2002, 12:28 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
This does the same thing as Pauls suggestion, have one person sit in the car while you bleed the brakes, it doesn't matter left or right. Have your helper only gently push the pedal until the light goes out. You will need to bleed opposite the end you did last.
Outlawed tunes from outlawed pipes
