Check crank with plastic guage help!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2007, 05:19 PM
Folks, I can't find information on this anywhere. I bought plastic guage strips to check my crankshaft bearing mains on my 350 small block chevy but I can't find instructions on how to use it and what I am looking for. Does anyone out there have the information I need? I am installing a new 400 crank in my freah 350 block and want to make sure things are right!
Old 07-22-2007, 05:35 PM
you need to start with a dry and clean crank and mains( caps and block). with NO lube or anything else. lay a small strip of plastigage on the journal going across the radii of the journal. torque the cap to specs. and using the sleeve the plastigage came in, reading the inch side match up the thickness of the flattened plasigage to the gauge on the sleeve. that is the oil clearance that the bearing has. now do the same to all the rod bearings also. after you have done that, clean the bearings and journals off with brake clean or equiv.have fun
Old 07-22-2007, 06:17 PM
King of my Man-cave.
Actually, plastigauge was designed to be used on cranks that are in service, so they are supposed to be lubricated. That's why the directions say to wipe off the oil where the plastigauge is to be applied.
tom
Old 07-22-2007, 07:07 PM
Last journal entry: frame build
Don't just rip off a piece of it. That will distort the reading because stretching it makes the diameter smaller. Cut it with a sharp knife or razor blade or scissors. use a piece as long as the bearing is wide. Don't remove it from whatever it sticks to before measuring.
Old 07-23-2007, 04:54 PM
Thanks
I knew you folks would come through. Does anyone know what measurements I am looking for? The plastic guage cover has a measurement range on it. How do I find out what the min and max is for my crank?
Old 07-23-2007, 05:36 PM
383silverado's Avatar
are you a building a 383 or 377 ?
4.030 bore 3.75 stroke= 383
4.0 bore 3.75 stroke=376.99
i think the mains have to be turned down in order to use the 400 crank in a 350 block.
http://www.chevymania.com/tech/383.htm
Old 07-23-2007, 07:50 PM
techinspector1's Avatar
Wiki Edits: 326
I think what you're looking for is the suggested bearing clearances. For a street motor, 0.0020" (two thousandths) on the rods and #1 through #4 mains with 0.0030" (three thousandths) on the #5 main. A little less will be ok, a little more will make the crank and rods rattle a little with thin oil and will contribute to low oil pressure. On a high-perf motor with a premium oiling system, you would want to open the clearances up another 0.0005" (half a thousandth), also called (five tenths) or (five ten-thousandths).
Side clearance for each rod pair on the big end, 0.014" to 0.020" (fourteen thousandths to twenty thousandths).
Crankshaft end play, 0.003" to 0.008" (three thousandths to eight thousandths).
Each builder has his favorite clearances and we'll probably hear from some others on this subject.
Old 07-24-2007, 09:11 AM
techinspector1
techinspector1, thank you that was what I was looking for! Great help all!
bought a stroker crank... or did i??? 280zxWith305 Engine 6 02-18-2005 06:40 PM
383 Crank Hits Pistons 68NovaSS Engine 17 08-09-2004 02:33 AM
crank problem Zartan Engine 17 05-11-2004 02:39 PM
400 Crank sb72elcamino350 Engine 3 04-15-2004 02:42 PM
crank / block combo's toddtheodd Engine 5 03-17-2004 10:38 PM
