Check Engine Light 2004 Mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2010, 09:14 PM
My check engine light was flashing, along with ABS and the car would sputter, so I took the car to AZ and they said possible the crank sensor or plugs. I have changed both and the car does run much better, and does not sputter but the light will not go off. Can anyone tell me how to turn it off?
Old 05-30-2010, 09:22 PM
327NUT's Avatar
Take it back to AZ and they can cancel the light with thier diagnostic equip.....if the problem is taken care of.
Old 05-30-2010, 09:26 PM
thanks will try that tomorrow
Old 05-31-2010, 07:36 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It could possibly be a ignition coil going south on you also if what you done does not fix the problem completely. JMO
Cole
Old 05-31-2010, 08:48 AM
sbchevfreak's Avatar
Licenced Automotive Technician
AZ has no idea why the light is on. All they have is a code reader, and a parts monkey who likely has no automotive repair/diagnostic training. If the MIL is flashing, you have a serious issue, that will cause catalytic converter damage. If you, can, post the codes here, and we will try to pin it down for you.
Check engine light is "on" kleen56 Electrical 11 02-18-2009 01:01 AM
installed exhaust kit.. check engine light came on dhomsey Engine 9 01-06-2006 12:41 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Trans Am Check Engine Light Guitarman Engine 2 04-23-2003 06:03 PM
Tune Up. Check Engine Light way_2fast_4u Engine 1 04-21-2003 09:49 AM
