Check Engine Light-EEC IV - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 04:32 PM
I have a '93 Mustang LX Conv with a 2.3 DIS 4-cyl dual plug engine. The check engine light came on and I ran a code check. I got a code 332 which is a problem with the voltage in the EGR system. I have Haynes, Chilton's and the Ford manuals and can't find out how to repair and clear this code.
I have switched the EGR with a known good unit and this didn't help.
Any suggestions or help would be welcome....thanx, Pliskin
Old 10-29-2006, 07:35 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
You probably have a bad dpfe (digital pressure feedback egr) Its a sensor that measures back pressure from exhaust egr tube to monitor and control egr valve flow. Its a small tan or white box with 3 wires and a hose hooked to it. Those things drop like flies.
Old 10-29-2006, 07:40 PM
71lifeliner's Avatar
Old Rodder
After replacing the dpfe if the code does not reset on its own.Disconnect your battery for 3 minutes and then hook it back up.This should reset it.Some say it only take a few seconds to reset after disconnect but I have found that 3 minutes works best on this particular code.This is a common problem with FoMoCo.
Old 10-31-2006, 04:44 PM
re: Check Engine Light
Thanx 67 Duece 4 me and 71 lifliner for the feedback on my EGR (check engine light) problem. Will give it a shot with a new dfpe....thanx again. pliskin
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Engine check light rfltz Introduce Yourself 12 07-07-2006 12:01 PM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 11:02 PM
Check Engine Light? TonyMac Engine 4 05-29-2004 12:22 AM
