check engine light on in my 2001 dodge neon - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2006, 02:02 PM
Hi, I have a 2001 Dodge Neon, and last Monday the engine light came on while I was driving home. No other lights came on, nothing seemed to be wrong. It was driving normal. I took it to Auto Zone and they checked it and it said that "the voltage signal from the power steering pressure sensor is out of range for the current engine operating conditions." The man said they did not have the part that I'd have to go to the dealership, but that it could also just be low on fluid. All has been checked and all is good. My steering doesn't feel any different. It is not hard or anything. Would that be normal? I'm afraid to take it to a dealer or anyone and have them charge me a fortune for nothing, but then I have 3 children and don't want to end up broke down on the side of the road somewhere. If anyone has any other ideas of what it could be I would love to hear them. The power steering just doesn't sit well with me for some reason. Thank you!!
Old 02-21-2006, 02:04 PM
97Z28's Avatar
NTI Grad.
if you have power steering fluid in the resivoir then that means the pressure sensor is bad.
Old 02-21-2006, 02:08 PM
OK, but would my steering still feel normal?
Old 02-21-2006, 02:12 PM
engineczar's Avatar
along the same lines if the resevoir is at the correct level, there are no leaks, and the steering feels ok without any binding then it may be just a bad sensor. Did Autozone clear the code for you? If not see if they will then see if it comes on again at a later date. It's possible that the belt slipped due to moisture and the pressure dropped long enough to set the code.
Old 02-21-2006, 02:19 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I am not sure about Dodges, but on a Ford if you disconnect the battery for a few minutes it will erase the code light. Of course it will also erase all your radio programming.
Afterward, you can see if the light comes back on. IF it does, and if it is the fluid level sensor, that sensor is easily bypassed.
Old 02-21-2006, 02:23 PM
97Z28's Avatar
NTI Grad.
yeah, your steering would feel normal because you still have pressure in the system. But with a bad sensor it is telling the computer that your system pressure is too low therefore throwing the code.
Old 02-21-2006, 02:30 PM
No. Auto Zone did not clear the code. They told me once I got it checked out I could bring it back up there and they would clear it for me. I just haven't gone back up there. I actually haven't drove it much. He told me not to worry that it was not something that would leave me broke down on the side of the road, but when lights come on, it scares me. If this is what is wrong, could it leave me broke down on the side of the road?
Old 02-21-2006, 03:32 PM
xntrik's Avatar
NO it might get hard to steer like manual steering, but a total system failure will not stand you on the side of the road.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
2001 Dodge neon help. hcker2000 Hotrodding Basics 5 02-17-2006 01:59 PM
Check engine Light 97 E-150 van nomad1 Electrical 8 01-02-2006 06:45 AM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
dodge 2.2 engine Terry Davis Engine 7 04-22-2002 09:22 PM
