Check Isuzu chassis for early rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2006, 07:59 AM
cboy's Avatar
Last journal entry: Finished
We've had many many discussions about putting mini truck frames under early rods (both full fendered and open wheel cars) and I've usually been the first to warn against them...due to the cluttered and often ugly appearance, especially for open wheel cars. But I may be changing my tune after seeing this thread new project
Since some of you don't read the "Lounge/Introductions" forum I thought I'd cross post this to "suspensions" for those of you who might have missed it. The Isuzu is the first mint truck frame I've seen that might have some real potential for even an open wheeled rod.
Here is one pic of erni's frame from that thread.
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 09-21-2006, 09:07 AM
ckucia's Avatar
Thanks for moving this here, Dewey.
I don't frequent the Lounge all that much - the rest of the forums already take up too much of my time at work.
Pretty interesting stuff. Only thing I would like to change if the frame was on an open-wheeled car is what appears to be the shock tower mount - effective but sort of ugly.
Otherwise, it looks like that suspension has a lot of potential, at a low price, and it isn't all that unattractive.
Seems from the other thread that this is a torsion bar setup?
Old 09-21-2006, 02:52 PM
Wiki Edits: 31
the Izuzu pickups are the same as S10 Pickups, at least in the later years I'm shure of, not shure about '92
Old 09-21-2006, 03:06 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
That frame looks nothing like my S-10 frame
Steve
Old 09-21-2006, 03:42 PM
Wiki Edits: 31
Steve
must be just the later '94 up Izuzu's then. I know in those years they are the same, altho grills are diffrent, the rest is the same. my friend at the boces auto tech class I take is bringing in his '92 Izuzu truck for some work pretty soon. we have a '90 S10 blazer that has no motor in it sitting outside the shop. I'll check for what diffrences they have exactly.
Old 09-21-2006, 10:17 PM
Last journal entry: cab on frame
It does have a torsion bar setup. ernie
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
First stage of rebuild, chassis first? Oz GMHR General Rodding Tech 6 06-26-2005 11:36 AM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 06:50 PM
new rods or old rods? Blob Engine 12 02-03-2004 04:35 PM
check out these rods!!! mustangbaby Hotrodders' Lounge 1 06-18-2003 12:01 AM
