hi
can you help me please in my first engine ?? I am planing to build a 383 stroker for my weekend ride (83 camaro) here are the specs chevy 350 block bored to 4.030 all forged rotating assy. with 6" rods CR 11:1 approximately heads Canfield aluminum 220cc http://www.canfieldheads.com/sbc_2600.html Intake Victor Jr ( is there any benefit of using spacers ) carb need help Ignition HEI with MSD 6AL cam Crower solid roller for nitrous # 00552 Advertised Duration: Intake 290°/ Exhaust 296° Duration @ .050": Intake 254°/ Exhaust 262° Lobe Lift: Intake .391"/ Exhaust .408" Gross Lift(with 1.5 rocker arms): Intake .587"/ Exhaust .612" LSA : 114º intake centerline: ???? I don't know transmission th350 converter ???? gears ???? is this a good combo ??? can I use pump gas with this CR?? can you estimate the horsepower & torque for me please? Any comments are appreciated thanks |
hi
406chevelle you are right the CR seems to be high but I've calculated the DCR it is very low = 7.92 thanks bro it was my fault to post it here can anyone move this to the ENGINE forum
More Parts
What crank are you going to use? Are you going to use rollers? Heavy duty oil system? Timing gears or chain? Sump pan? Carb 650? Headers? What shape piston? 2400 Stall TC? 342 gears? Posi rear? Spacer helps.
Hope this helps. hr41pearl
I like Edelbrock carbs. I run the stock oil pump but a deep pan looks cool and requires a special oil pump pickup installed on the pump, available at Summit installed. The 2400 stall is sufficient. I don't use anything extra to seal the intake but the gasket and torque to specs. The cat crank for a 400sbc is inexpensive and I haven't had any problems with mine, will require a machine shop to setup the crank, rods for clearance and ballanceing the rotating assembly. If you haven't done it before have the engine/machine shop gap your rings and space the crank and rod brngs for proper clearance. Did you say your going to put juice/nos to the 383? You would have been better off using the stock 350, but thats just my opinion, your going to blow up your engine eventually so why waste all that money on a 383 just to have to do it all over again when it blows??
Tazz Rat Rods Rule! Last edited by tm454; 01-17-2004 at 09:15 AM. |
hi guys
I will use complete 4340 forged bottom end with AFR210 or canfield220 or DART PRO 1 CNC and ofcourse I will use a deep pan Quote:
I intend to spray 250 - 300 hp shot of nitrous thanks |
You will be able to run pump gas for sure with that combo. I have an 11:1 400 with iron heads, 234o of duration, and 36o total advance, it doesn't ping. I can only get 91 octane in my area too.
