Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Check my valve spring specs for cam break in
Old 06-20-2013, 09:36 AM
RyanR RyanR is offline
Hey guys getting ready to install and break in my Lunati Voodoo 268 hydraulic tappet cam and just wanted y'alls opinions on my springs to make sure their not too stiff. I'd hate to wear down a lobe or lifter on break in Thanks for your time and help guys.
Spring pressure closed 115 lbs @ 1.800
Spring pressure open** 310 lbs @ 1.225
Coil bind is 1.130
Install height is 1.800
Max valve lift is .575
And here are the cam specs
Advertised Duration (Int/Exh): 268/276Duration @ .050 (Int/Exh): 227/233Gross Valve Lift (Int/Exh): .489/.504LSA/ICL: 110/106Valve Lash (Int/Exh): Hyd/HydRPM Range: 1800-6200
