Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Check my valve spring specs for cam break in
Old 06-20-2013, 03:08 PM
RyanR RyanR is offline
Originally Posted by ericnova72 View Post
His new springs are good for .575" lift...but his cam is only .504" lift.
I'd check to see if the old vortec sorings will manage the .504" lift without going into coil bind, and use them for the break-in period if they will work. Give the cam every advantage you can during break-in.
Naw, I'm pretty sure the max is .470 on them.... seems like even more risk honestly than using my regular springs
