Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Check my valve spring specs for cam break in
Old 06-21-2013, 02:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The open spring pressure is 310 pounds- but at 0.575" lift. The pressure at close to 0.500 is going to be well under 300 pounds.
I have broken in FT cams w/springs similar to this- but that was then and this is now. I believe if you're careful and follow all the rules, you'll be OK. But then, I won't be repairing it if it goes wrong.
The Following User Says Thank You to cobalt327 For This Useful Post:
RyanR (06-21-2013)
