Check your lugnuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2008, 10:50 AM
powerrodsmike's Avatar
Wiki Edits: 161
Check your lugnuts
This is a very good reason why you need to check your lugnuts, especially with alloy wheels. Luckily the wheel came off while turning into a driveway, so no one was hurt.
I never saw a loose wheel pull the studs out of a rotor, usually they just shear and let the wheel fall off....but now I have.
This is a 4x4 Ranger pickup wheel, with the locking hub still held in the wheel by the 3 studs that pulled through.
Check your nuts regularly.
Later, mikey
ID:	33463   Click image for larger version
ID:	33464   Click image for larger version
ID:	33465   Click image for larger version
ID:	33466   Click image for larger version
BE different....ACT normal.
Old 10-23-2008, 12:08 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Aww man, that sucks. Definitely could have been worse.
I have never lost a wheel on anything- knock on wood- but I will heed your advice.
I use a torque wrench on my stuff. Alloy wheels are kinda bad about this too.
Old 10-23-2008, 12:58 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I first heard about this 11 years ago from a off road race team owner. His personal truck he used to pull his buggy had alloy wheels, and he told me they had come off in the past. He also said that he had to re-torque them after 100 miles, and again after another 100 miles.
Since I heard of this, I have no longer used a 'impact' to tighten lug nuts on any type of wheel. I only use a torque wrench, and request everyone with alloy wheels to come back after 100 miles for a re-torque.
This had become a 'habit' to me, and I did not think, or have not thought about it since. I also did not think about it being important enough to add to my "posts" page on my own website. It will be added now!
Thanks for the 'cup of coffee', or 'wake up call' Mike
Old 10-23-2008, 01:21 PM
Wiki Edits: 161
I sent a truck home with a guy one time with a brand new set of Torque thrust wheels that I had torqued on with a Torque wrench...Told him to retorque his wheels after 50 miles, then 200, then check once every thousand miles or so. Even wrote it on his receipt.
He said he had a good torque wrench, but apparently it never came out of the tool box. He lost a front wheel after about 300 miles.
I always double check each wheel, and torque wheels on every car that comes in here.
BTW, the truck in the first post belongs to a relative who has never had the truck anywhere near my shop.....till now.
Later, mikey
Old 10-23-2008, 01:55 PM
THERE ISN'TANYTHING WRONG WITH MY NUTS!
Oh you said lugnuts, good thing nothng worse happeded to the truck.
Old 10-23-2008, 04:23 PM
Wiki Edits: 31
I just got a '92 Ranger 4x4 with the alloy wheels, havn't checked the lugnuts, but tomorrow, I'm gonna put the torque wrench to them... my mom used to have a problem with the wheels on her '02 concorde, as they would loosen themselves up.. the lug seats were worn out, so we went to the junkyard and got a set of '96 Intrepid wheels ( same car/ tire size ) with really nice tires.. fixed and looks sportier
Old 10-23-2008, 08:18 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
But------be careful not to over tighten
Did this on my 59 and lost 2 studs. Galled and would not loosen up
Now a little anti-sieze and no more "gorrilla" wrenching
Old 10-23-2008, 08:21 PM
Bryan59EC's Avatar
Mikey-----that looks like an aluminum hub.
Something tells me that an aluminum hub, 4x4, and steering will not quite go together. Especially in "lock" or low gears.
Old 10-23-2008, 10:22 PM
Wiki Edits: 161
On the Rangers, Explorers, and other compact ford 4wds, the locking hub has a flange that is sandwiched between the rotor and wheel. Those are expensive, and if you replace one, you are supposed to replace the other. At 190.00 each for some new ones off of ebay, that wound up being the most expensive part of the whole job.
A new junkyard rim was 97.00. 2 rotors were 22.00 each,(for 22.00 why replace only one) new set of pads were 25.
I'm going to do enough hack bodywork to let the door swing open...practice my PDR skills..
Later, mikey
Kia fuel pump, again! oldred Electrical 150 07-15-2010 08:32 PM
4l60E electronics check Mike_J Transmission - Rearend 7 03-14-2008 06:23 AM
Things to check out when buying a new car k2mooch Hotrodders' Lounge 7 08-17-2004 03:34 PM
Self Check Out //Fast Lane//-Stupid Ghetto Jet Hotrodders' Lounge 25 07-27-2004 07:29 PM
