Checking 220V Outlet - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 10:58 PM
daveh's Avatar
Hey Guys,
I just finished installing my 220V outlet for my Miller 211 Welder. Plugged it in and the welder turned on fine. I didn't test the welder. I checked the outlet with one of those cheap test lights and it read 220 volts.
My electrician friend who told me how to do it is out of town. I want to really verify it with my digital multi-meter but don't know exactly what holes to put the leads in and where to set the dial. Can someone please tell me so I can triple verify that I have it correct? And what exactly should it read?Thanks
Old 02-19-2011, 02:35 AM
SSedan64's Avatar
Outlet like this>> http://www.brwelder.com/images/EXTEN...RD%20PLUGS.jpg
Set your Volt/Ohm meter to ACV=ACVolts, probably has a settings of 200, 400, 700 etc.. Use 200 setting, insert the Black probe in the Horse Shoe looking hole, insert Red probe in either Flat blade hole. Should have about 120-125V on each Flat blade hole contact.
Old 02-19-2011, 06:53 AM
daveh's Avatar
Isn't there a way that I can check the total voltage at once and get a total voltage number instead of checking each spade separately? Thanks
Old 02-19-2011, 08:10 AM
Yeah, simple. Put the VOM on a scale higher than 200V AC. Put one probe in each of the main terminals. You'll see 220V (or close to it). No, it does not matter that one probe is the "GRD" probe.
Old 02-19-2011, 11:55 AM
daveh's Avatar
I know I being really stupid but I want to be certain before I go sticking leads into the receptical.
This it the tester exactly where do I put the leads and on what settings and where? Thanks
Dave
Old 02-19-2011, 01:45 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
With that meter I would check one side at a time, as you may damage the meter trying to use it on higher voltage then the meter is rated for 200VAC
Rich
Old 02-19-2011, 03:15 PM
daveh's Avatar
I checked my 110 outlet first to test and get readings of 7.5 shouldnt it be close to 110? What am I doing wrong? I have the meter on V AC 200. Thanks
Old 02-19-2011, 03:32 PM
bondo's Avatar
Ayuh,... With the meter pictured, 'n the selector where it is at 200V, AC...
Put the black lead in the center, 'n the red in the right side hole of the meter...
With the leads in a standard household outlet, you should see 110V/ 120V showing...
On the welder receptacle, you should see 120V from each side, to the common...
The red lead on each side, 'n the black lead on the common...
Old 02-19-2011, 03:58 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
daveh, that meter has a 750 VAC setting. Set it to 750 VAC then do just as joe_padavano said and stick one lead in each main terminal. It doesn't matter which lead goes on which side you should still get the ~220v you're looking for. I just got done checking all of the 110v and 220v outlets in my shop with a cheap digital multimeter and it worked fine. You just have to make sure you have the meter on the right setting.
Old 02-19-2011, 04:04 PM
Blazin72's Avatar
Wiki Edits: 19
I searched and found this. It describes both methods people have listed above. When measuring 220v directly just make sure you have your meter set to 750 VAC.
http://www.ehow.com/how_5933454_test...er-outlet.html
Old 02-19-2011, 04:17 PM
daveh's Avatar
Eureka I did it. I had the lead in the wrong hole. Once I figured that out it worked great. Hey you learn something every day. I couldn't have done it without you guys. Thanks again I always appreciate your help.
Dave
Old 02-19-2011, 04:27 PM
Blazin72
When I looked at the meter I thought it read 150 then 200, after you said something about it I expanded the picture then I could see it read 750.
Rich
Old 02-19-2011, 05:00 PM
Blazin72's Avatar
Wiki Edits: 19
Yeah I had a hard time reading it too. I had to blow up the picture to read it clearly. I may be 29 but my eyesight is about 30 years older than I am.
Old 02-19-2011, 08:05 PM
For what it's worth, even the $2.99 Chinesium voltmeters at Harbor Freight have 200 VAC and 750 VAC scales. It would make no sense to built a meter with 150 V and 200 V scales, since they are so close that one would be redundant.
Checking pushrod length with checking springs? v8hed Engine 1 01-22-2011 06:20 PM
Water Outlet? hemi joe Engine 13 10-30-2009 03:30 PM
Wiring for a 230V MIG asennad Garage - Tools 10 11-17-2006 05:21 AM
Why are some 230v compressor motors run on 110v? Danny G. Garage - Tools 11 05-22-2006 07:37 PM
Wiring my 230v compressor...... PairOf69's Garage - Tools 7 11-18-2005 08:04 PM
