checking Amperage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 02:03 AM
checking Amperage
How does one get an amperage reading - is this taken when the machine is underload , and where is this usualy taken in line from
Old 06-12-2009, 06:43 AM
302 Z28's Avatar
Amperage is measured with an amp meter that is placed in the line that feeds the fuse panel. That means that any load the fuse panel requires must pass through the amp meter. They have been deemed dangerous by some for that very reason and a volt meter is the preferred alternative.
Vince
Old 06-13-2009, 07:56 AM
measuring Amperage
Thanks Vince
What I need to know is, once the Ampmeter is set to the correct Amperage , which of the probes are used , is is there one across the main fuse ie posative , neutral either side - across ?
thank you for the assistance
Fahr
Can a votage measurement and a calculation arrive back at Amperage.
Old 06-13-2009, 02:08 PM
302 Z28's Avatar
Originally Posted by Fahr
Thanks Vince
Fahr.
You must find the main power feed wire to your fuse panel, disconnect it at the source and place the positive amp meter lead where you lifted that wire. Place the negative amp meter lead on the wire you lifted. Now all the current will be flowing through your amp meter.
Warning: make sure the wire size you are using for your amp meter is of sufficient size to handle the anticipated load.
Can a voltage measurement and a calculation arrive back at Amperage.
You cannot figure amperage with just a voltage measurement you must have one other factor in the formula as follows.
To find voltage, [V = I x R] V(volts) = I (amps) x R(ohms)
To find current, [I = V / R] I(amps) = V (volts) / R(ohms)
To find resistance. [R = V / I] R(ohms) = V (volts) / I(amps)
Vince
Old 06-13-2009, 09:44 PM
Most small hobby "ammeters" measure milliamps, and do not have a scale high enough to use on a car. If you put one inline in the circuit, it will probably fry the ammeter.
Automotive ammeters usually have a shunt arrangement (which has a known resistance) that uses the formulas listed by 302 Z28. The principle is that if you measure the voltage at two points, and have a known resistance between the two points (that is the value of the shunt), the meter can calculate an amperage.
Another option is one of the inductance ammeters, where the meter probes are shaped like two short arcs, and you just surround the wire where you want to measure amperage. They are more expensive meters, but you don't have to disconnect any wires to use them.
Bruce
Old 06-14-2009, 07:20 AM
302 Z28's Avatar
Bruce
In industry those are known as "CT's" (current transducers) and are commonly used on large motors. The CT is placed on the "T" leads of the motor to measure amperage. Three phase motors will typically have one on each phase leg.
Vince
Checking V-P clearance after head mill... 540neverdone Engine 6 05-17-2009 07:04 PM
Need to upgrade to higher amperage alt. Jmark Electrical 3 11-27-2007 08:51 AM
Checking Amp Draw with a Multimeter... 71gtx Electrical 6 05-28-2007 07:57 AM
12 Volt battery Amperage check? tm454 Electrical 7 01-28-2003 12:06 PM
